intake length 3.5 to 3 inch v stack
Old Mar 20, 2013 | 10:48 PM
raverx3m's Avatar
Default intake length 3.5 to 3 inch v stack
im finishing up the Px install tomorrow and hopefully will have a spot on the dyno with this race wars goin on next month.( which also happens to be my emission testing month)
heres the updated setup
GSRlong block 12.2-12.6 CR according to zeal
pr3 pistons 81.5 bore
BC3+cams supertech 60lbs springs
supertech flat faced valves,milled .015-.02(not sure how much was milled by previous owner)
PX manifold 70mm TB portmatched
ebay 3 inch SRI with 3.5 v stack and filter
ebay Tri-y rep. header merged to 2.5 flexpipe and hiflow cat with vibrant muffler
205/50/16 tire
old picture that shows intake tube with old filter
its been cut right at the cross section between dizzy and shock tower to fit the v stack under hood so i can use that section to add 3.5 pcv pipe that way i can slide it in and out to increase/decrease length.
i would like some advice what would be a good starting point for the pipe length?
whats the most common length ratio between 3 and 3.5 inch pipe for the intake?
Old Mar 21, 2013 | 03:13 AM
AaronEJ's Avatar
Default Re: intake length 3.5 to 3 inch v stack
Mostly its something between 700-950mm length
Old Mar 21, 2013 | 08:37 AM
raverx3m's Avatar
Is that for 3 inch or 3.5 part?
Old Mar 21, 2013 | 02:58 PM
AaronEJ's Avatar
thats for the total length, i would try 40% 3.5" and the rest of the length 3"
Old Mar 21, 2013 | 05:37 PM
01DC4's Avatar
been thinking about doing the same thing myself, in for more info.
Old Mar 25, 2013 | 03:59 PM
raverx3m's Avatar
soooo i had some time today.
after i spent about 2 hours trying to find a piece of 3.5 pipe
went through my garage and found a bottle of acetone that was just what i needed.
and while the kid was sleeping i made this
SONNEEZYex97
Mar 25, 2010 08:26 PM
blitzed310
Sep 28, 2006 12:20 AM
tekstyle
Jan 2, 2004 07:08 PM
BolivianDc2
Sep 21, 2003 08:40 PM
