93 del sol fog lights?
Old Mar 20, 2013 | 09:12 PM
Mark-e's Avatar
Default 93 del sol fog lights?
Hello forum,
I am new to this forum and the honda scene in general. I have not yet done an intro but I will once I get pics of my car. Anyways this might seem like a dumb question but well here I go.
Are the smaller round lights on the front of a del sol driving lights or fog lights? The reason why ask is mine dont turn on. I checked all the fuses by the pedals inside the car but they are all fine. Then I checked the fuses under the hood and only one 20amp fuse was popped but it didnt have a label so I just replaced it in hopes to get the lights t work but nothing. I have some aftermarket lights and oem lights but none work... any suggestions? Thanks in advance
Old Mar 20, 2013 | 09:22 PM
jbpnoman's Avatar
Default Re: 93 del sol fog lights?
Yes, they are "fog" lights. They're more decorative than functional though - mounted too high to function as proper fog lights.
Old Mar 20, 2013 | 09:29 PM
Mark-e's Avatar
Yea I knew they would be. Thats why I wanted to put in some yellow light so they wouldnt shine in ppls mirrors and still look decent. But I cant get them to turn on?
Old Mar 20, 2013 | 09:35 PM
jbpnoman's Avatar
You could have a break in your grounds, or the switch could be bad, or the relay could be bad. Do you have (or have access to) a multimeter?
Old Mar 20, 2013 | 09:49 PM
Mark-e's Avatar
Nope dont have a multimeter or access t one... it probably is one of those situations tho. How would I check for this though?
Old Mar 20, 2013 | 09:51 PM
jbpnoman's Avatar
You would need a multimeter. You can buy one for fairly cheap at Sears, or your choice of auto parts stores. Get an actual multimeter - a test light is not good enough.
Old Mar 20, 2013 | 09:54 PM
klav07's Avatar
could be a dumb question but... are you hitting the switch while your headlights are on?
Old Mar 20, 2013 | 10:31 PM
Mark-e's Avatar
I think my answer is going to be dumber..... but what switch? Ive never had fog lights before. The headlight and driving light lever? or do you mean the push switch on top of the gauges? Damn I feel real noobish asking these questions
Old Mar 21, 2013 | 03:42 AM
NVturbo's Avatar
O.G. triple O.G.
Yeah...the fog light button is ontop of the gauge cluster/dash.
Old Mar 21, 2013 | 03:47 AM
belairbrian's Avatar
The switch is labeled AUX not fog and yes the low beams must be on for them to function. When you go to high beams they turn off as well.
Old Mar 21, 2013 | 06:03 AM
Mark-e's Avatar
wow... it worked! feeling really noobish right now.... but thanks all
redline870
Jul 5, 2009 10:24 AM
yESSSmAn
Apr 15, 2009 07:42 PM
eclaire
Mar 6, 2009 11:06 AM
srg
Jul 20, 2006 08:32 AM
icyredsol
Apr 11, 2003 06:43 AM
