Bent Crank Shaft
Hi Guys! I have a 94' Honda Accord EX. 190,xxx miles on it. I was having problems with shifting and reversing. To me it was a sure shot sign my tranny was slipping got a new tranny put in the car and it died the very next day. I noticed the serpentine belt was'nt spinning and car was making a loud noise to it to a mechanic he said I need a whole engine beause my crank shaft is bent or broken and causing the pulley to shift thus why the car wont start and the belts arent moving. So my question is do I really need a whole new engine or can I just get the crank shaft replaced. I don't know or didn't know much about cars untill I got this one.
I'd like to know what happened to bend the crank..... are you sure he didn't say camshaft? Or maybe you threw a rod!.....
It is not a very common issue with these engines. I have ever heard of it happening anyway..... However, I'm not doubting your mechanic and if the crank is truly bent. Replacing the crank is not something that is usually done with the engine in the car. It would be cheaper for you to get a used engine and swap it in whole rather than taking the time to machine a crank and replace it....
even being able to do all of the work yourself (asside from the re-machining of the crank) removal, teardown, inspection, rebuild, reinstall- you're still looking at $400~600 in machine shop labor and rebuild kit parts. and, also 2 weeks to a month or more with the car out of comission. believe me, i did this just two months ago!
I'm thinking it's time to decide if the car (condition/value) is worth the $2,000 you're probably quoted for the replacement by your mechanic. (I guess... it's been a while since i checked labor costs on this job) it seems silly to have to decide between an expensive fix or letting the car go over such a seemingly small area of damage, but if you plan to keep the car for a while you'll want the right repair so you won't have trouble later.
this was my thought as well. however, if there is in fact damage to the crankshaft even just a slightly knarled "snout" and key way where the pulley fits the best fix is still a low-mileage, used motor replacement.
I'm thinking it's time to decide if the car (condition/value) is worth the $2,000 you're probably quote cement by your mechanic. (I guess... it's been a while since i checked labor costs on this job) it seems silly to have to decide between an expensive fix or letting the car go over such a seemingly small area of damage, but if you plan to keep the car for a while you'll want the right repair so you won't have trouble later.
jsnock
Feb 21, 2007 09:45 AM
