93 Civic OEM HELP NOISE PROBLEM!
Old Mar 19, 2013 | 08:35 PM
jroderick619's Avatar
Icon3 93 Civic OEM HELP NOISE PROBLEM!
i hear a rotating Rubbing problem.. it sounds like ball bearings.. but it only happens when im in gear... what is it???? can it be my transmission or Axel?
Old Mar 19, 2013 | 08:37 PM
B_Swapped93's Avatar
Default Re: 93 Civic OEM HELP NOISE PROBLEM!
Could be you'r throw out bearing. or perhaps you axel isn't seated properly but i don't think that's it
Old Mar 19, 2013 | 09:00 PM
jbpnoman's Avatar
Standard or automatic? Where is the sound coming from? Only when moving, or when stationary in gear?
Old Mar 19, 2013 | 09:06 PM
Tegboosted760's Avatar
it also could be your shift linkage hitting the exaust that would give it a rubbing metalic sound
Old Mar 19, 2013 | 09:16 PM
Standard.
Coming from underneath engine
only when moving.
Old Mar 19, 2013 | 09:17 PM
um.. how would i go about checking that.. what do i look for???
Old Mar 19, 2013 | 09:18 PM
jbpnoman's Avatar
If your foot is off the clutch in neutral, do you hear the noise?
i'll put up a video tomorrow hopefully it'll explain my situation alot better
Old Mar 19, 2013 | 09:22 PM
i dont hear the noise, only when its in gear coming to a slow stop..
Old Mar 19, 2013 | 10:35 PM
jbpnoman's Avatar
When was the last time your transmission fluid was drained and refilled? Have you checked it's levels? Have you checked your clutch fluid levels? Does the clutch feel like it's slipping at high RPMs?
Old Mar 21, 2013 | 09:02 AM
the last owner said he did the transmission fluid flush 9 months ago.
he replaced the clutch 2 weeks before he sold it to me. (had the paper work also)
i do not know how to check my transmission fluid >_< any tips??
i also attempted to post a video but you wouldn't be able to hear the sound because my exhaust is too loud...
Old Mar 21, 2013 | 09:07 AM
if i were in need to do a transmission fluid flush. what should i use?
and where is the best place to purchase?
93 civic Dx Manual transmission.
Old Mar 21, 2013 | 12:26 PM
strategy400's Avatar
Pull the inspection cover and have a peek with a flashlight. Look around while your down there.
2kdrift
Dec 3, 2010 09:14 PM
DaveSi677
Nov 4, 2008 07:18 AM
slowpokecivic
Sep 30, 2005 01:59 AM
Crucial_CiviC
Aug 21, 2005 09:19 PM
Bob98EXCoupe
May 10, 2005 05:18 PM
