1993 eg coupe ex with B16 a2 swap. RPM GAUGE NOT WORKING "HELP"
Old Mar 19, 2013 | 06:58 PM
08mugen-si's Avatar
Default 1993 eg coupe ex with B16 a2 swap. RPM GAUGE NOT WORKING "HELP"
I have a 1993 eg coupe ex with a B16 swap everything works fine on my cluster exept my RPM gauge i tried a different cluster from a friend and still not working, so i know its not the cluster. Im stuck what can it be. If you can help it would be great. Thanks
Old Mar 19, 2013 | 07:08 PM
B_Swapped93's Avatar
Default Re: 1993 eg coupe ex with B16 a2 swap. RPM GAUGE NOT WORKING "HELP"
you'r wire set up might be different what obd sys is you'r engine have a look at these pics
[/QUOTE]
Old Mar 19, 2013 | 07:44 PM
08mugen-si's Avatar
I have an obd 1. Any advice ie helpful. Thanks.
Old Mar 19, 2013 | 10:11 PM
FrodeyEJ1's Avatar
Try your vss
Google it and good luck
Old Mar 20, 2013 | 04:39 AM
if his vss was in-op his spedo,trip and vtec would not work. It's not related to the tach.
Old Mar 20, 2013 | 06:35 PM
08mugen-si's Avatar
Thanks for all the help. Still havent found the problem but not giving up. Im new at this honda stuff..lol.
Old Mar 20, 2013 | 06:38 PM
There's a green wire that is for the tach that should go to one of the cluster pig tails.(wish i had a pic to show you) but search how to install a shift light as it requires splicing into said wire. in short look to see if said wire is there and is giving a signal.
Old Mar 20, 2013 | 06:48 PM
Toofpik's Avatar
I have a similar problem with my b18a1 swapped eg. when i bought the car it had a p28 with a vtec map and it ran like **** but the rpms were good. as soon as i got a p75 in there the rpms were off. i read an old post somewhere and some guy had the same prob and he fixed it by swapping in a gsr cluster
Old Mar 20, 2013 | 07:39 PM
08mugen-si's Avatar
Oh ok. I bought the car with the swap in it already . Let me know what you guts think is a B16a2 obd1 with p28. Is that good or bad?.
Old Mar 20, 2013 | 07:41 PM
08mugen-si's Avatar
I will search for that thanks for helping me.
Old Mar 20, 2013 | 07:42 PM
b16a2 can be obd1 or obd2(or with a obd2 to obd1 jumper harness) AFAIK. p28 is fine
Old Mar 20, 2013 | 08:15 PM
08mugen-si's Avatar
Ok. Will check it out tomorrow and i will get back. I will check the wire thanks for all the information
Old Mar 21, 2013 | 06:07 AM
JuggerNaut-CTR's Avatar
This has happened quite a few times....
Unplug the distributor connector, and then measure how much resitance at the blue wire terminal. If the resistance reading is low (100 Ohms or less), then there's a short.
I bet the blue wire is broken or disconnected somewhere between the distributor and cluster.
Old Mar 21, 2013 | 07:01 AM
Rcourts's Avatar
near your driver side strut tower / clutch master area there is a single blue wire with a plug at the end of it.. if you connect that wire with the darkest blue wire on your dizzy, this should solve the problem
Old Mar 21, 2013 | 08:00 AM
08mugen-si's Avatar
ok i will try it today thanks for the help. i will let you guys know the results later today.
driftguy2008
Mar 3, 2013 01:56 PM
driftguy2008
Feb 28, 2013 07:01 AM
fml760
Jun 21, 2012 01:27 PM
falchi rice
May 18, 2007 01:36 PM
ImportechPerformance
Jun 10, 2005 08:19 AM
