Transmission & Drivetrain Gearboxes, Differentials, Clutches
5th Hub Issues (B-Series Mainshaft)
Old Mar 19, 2013 | 01:25 PM
NoWorry's's Avatar
Default 5th Hub Issues (B-Series Mainshaft)
Sup H-T,
I'm in the middle of assembling my ITR tranny and I ran into a slight issue with the 5th hub on the Mainshaft. My Helms manual calls for this hub and the 3rd/4th hub to be pressed on but only the 3rd/4th hub will press on.
The 5th hub easily fully slides onto the shaft and it honestly doesn't seem like it has any room to be pressed on. I even tried to tap it on slowly but it wasnt going anywhere. Also if I finish assembling the shaft/Press the bearing on, should the bearing by 100% flush with the top of the shaft?
Thanks in advance y'all, all my clearances are fine between 2/3 , 4/spacer , and 5/spacer and even on the hub but It says I should press on so I'm stuck?
-Ray
D21X
Oct 6, 2011 10:33 AM
Creator
Apr 14, 2011 06:03 AM
su8854
Nov 24, 2010 03:23 PM
zCivic
Aug 30, 2006 02:08 PM
txl146
Apr 10, 2005 11:33 AM
