96-98 fender as 99-00 civic interchangeable?
Old Mar 19, 2013 | 10:04 AM
miguey310's Avatar
Default 96-98 fender as 99-00 civic interchangeable?
96-98 fender as 99-00 civic interchangeable? because they look the same
Old Mar 19, 2013 | 10:15 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 96-98 fender as 99-00 civic interchangeable?
Look closer, They aren't.
Old Mar 19, 2013 | 10:18 AM
miguey310's Avatar
what area are they different? near the headlight area?
Old Mar 19, 2013 | 10:19 AM
BlazedD's Avatar
WestSPEC
They are interchangeable as long as you also change the bumper, grill, headlights, hood, and rad support.
Old Mar 19, 2013 | 10:21 AM
The Grumpiest
Answered your own question which leads me to believe you're looking for someone to tell you differently.
Old Mar 19, 2013 | 10:24 AM
miguey310's Avatar
can't i just use the old hardware and swap it into the other fender
Old Mar 19, 2013 | 10:41 AM
The Grumpiest
Go ahead since you're hell bent.
Old Mar 19, 2013 | 02:09 PM
datbumper's Avatar
No. You can't.
Old Mar 19, 2013 | 02:13 PM
carlos8's Avatar
they aren't the same, the have diferent headlight curve.
Old Mar 19, 2013 | 04:25 PM
Mad_Max_000's Avatar
so you have to use 99-00 fenders for either or...
Old Mar 19, 2013 | 04:57 PM
The Grumpiest
Or what? It's a yes or no question.
Old Mar 19, 2013 | 06:50 PM
VTECnician2's Avatar
99-00 fenders will only work with 99-00 headlights (which consequently will only work with 99-00 hood, bumper, and grill). so it is not a direct swap unless you want to do the entire front end.
Old Mar 24, 2013 | 02:31 PM
Thanks
Old Mar 24, 2013 | 03:39 PM
ef9kidlulz's Avatar
they are interchangeable just that its going to look shitty from the headlight area.
And whats up with that cat its like there is sand in his vagina
Old Mar 24, 2013 | 03:42 PM
The Grumpiest
Then they are NOT interchangeable. You can put on a shoe two sizes too small and it won't fit correctly. Same thing. It "almost fits" doesn't cut it.
ShinotakuX
14
Sep 22, 2007 05:31 PM
JLEK
Mar 13, 2007 08:43 AM
FUPAH8TR
16
Oct 8, 2006 09:36 PM
red93DA
Jun 22, 2006 12:10 PM
blkgsr03
Jul 10, 2002 11:10 AM
