B series motor swap
Alright, I am debating between two motors for a swap in my 98 civic. I used to drive a 92 Integra GSR, B17A1 DOHC VTEC blah blah blah, so I know the benefits of the B17. What I'm considering is the B16A2 from the 99-00 Si's. Based on price the B17 is clearly a superior motor, but for the price difference, what are the benefits of using the B16A2?
Dammit! People don't read any more do they?
https://www.google.com/webhp?sourcei...w=1920&bih=957
B17A1*
VTEC
Found in:
1992–1993 Integra GS-R (USDM Vtec Model Vin DB2)
Displacement: 1,678 cc (102.4 cu in)
Bore: 81 mm (3.189 in)
Stroke: 81.4 mm (3.205 in)
Rod/Stroke Ratio: 1.63
Rod Length: 132.28 mm (5.208 in)
Compression: 9.7:1
VTEC engagement @ 6000 rpm
Power: 170 bhp (127 kW) @ 7600 rpm & 117 lb·ft (159 N·m) @ 7000 rpm
Redline: 8000rpm
Fuel Cutoff: 8250rpm
Came equipped with the YS1 cable trans, which was different than other cable B-series transmissions as it has a different input shaft.
B16A2
VTEC
Found in:
1992 Honda Civic EDM VTi(EG9)
1992-1997 Honda Delsol V-Tec
1993-1995 Honda Civic EDM (EG6)
1996-2000 Honda Civic EDM VTI (EK4)
1999–2000 Honda Civic USDM Si (EM1)
1999–2000 Honda Civic CAN SiR (EM1)
1999–2000 Honda Civic Philippines SiR (EK4 sedan)
Displacement: 1,595 cc (97.3 cu in)
Bore×Stroke: 81.0×77.4 mm (3.19×3.05 in)
Compression: 10.2:1
Power: 160 hp (119 kW) @ 7600 rpm & 111 lb·ft (150 N·m) @ 7000 rpm
Transmission: Y21/ S4c
Redline: 8000 rpm
Rev Limit:8200 rpm
VTEC engages at 5200 rpm
Aluminum Casting
ECU Code: JDM P2T (square case) or USDM P30 (regular case)
OBD1(1992-1995) OBD2a(1996-1998) OBD2b(1999-2000)
You're tallking about a measly 10hp and 7ft/lbs of torque.
VTEC
Found in:
Compression: 9.7:1
Redline: 8000rpm
B16A2
VTEC
Found in:
Compression: 10.2:1
Redline: 8000 rpm
Rev Limit:8200 rpm
Aluminum Casting
em2Dima
Jan 29, 2012 06:29 PM
ted
Feb 10, 2005 05:37 AM
