Map spacer?
Old Mar 18, 2013 | 02:39 PM
Wilka's Avatar
Default Map spacer?
So I changed to a new intake and throttle body set up and noticed a piece of stainless steel under my map in between that and throttle body? What does this do? I googled it and supposedly is good for boosted cars but I'm NA, could this give false readings?
Old Mar 18, 2013 | 02:44 PM
B_Swapped93's Avatar
Default Re: Map spacer?
can you post a pic hard to visualize what you're saying
Old Mar 18, 2013 | 02:46 PM
Wilka's Avatar
it's literally a piece of stainless steel where the map sits, two extended screws. I'm at class right now so I will later
Old Mar 18, 2013 | 04:51 PM
grumblemarc's Avatar
The Grumpiest
Sounds like a Missing Link.
Old Mar 18, 2013 | 05:42 PM
doood's Avatar
been there done that
this. old tech nobody uses anymore except cheapskates. take it out.
Old Mar 18, 2013 | 07:24 PM
Wilka's Avatar
anyone know the threads? I need to get rid of the ridiculously long screws then lol
Old Mar 18, 2013 | 07:25 PM
Wilka's Avatar
Everyone keeps saying missing link but what is that?
Old Mar 18, 2013 | 07:29 PM
jbpnoman's Avatar
Is it really that hard to use Google?
http://www.inlinefour.com/missinglink.html
Old Mar 18, 2013 | 07:35 PM
I think OP took it to literaly and thought he was "missing a part" ? but yes he could have googled "missing link map sensor".
Old Mar 18, 2013 | 07:40 PM
doood's Avatar
take it to home depot. match up thread size in a shorter bolt. done.
Old Mar 18, 2013 | 08:56 PM
Wilka's Avatar
I work across the street from Lowe's good enough, just hope they have the thread matcher thing, aprox how long should it be?
Old Mar 18, 2013 | 09:27 PM
doood's Avatar
buy a few and try them. it's not brain science.
Old Mar 18, 2013 | 09:40 PM
Charlie Moua's Avatar
missing link and fmu..... awe... the good old days
Old Mar 18, 2013 | 10:07 PM
slomofo's Avatar
GDD Member
I haven't seen a missing link in years.
Old Mar 18, 2013 | 10:22 PM
apexi_rsx's Avatar
why not just cut the screws down with a 4" grinder?
Old Mar 19, 2013 | 12:36 AM
VTECnician2's Avatar
A "missing link" is a one way check valve to prevent your map sensor from reading more than atmospheric pressure on boosted cars. If the map sees too much positive pressure it will go into fuel cut and send the car into limp mode. It shouldn't affect your n/a car, but it would be safer to remove it. It's just one more part that can fail and cause headaches while troubleshooting.
Old Mar 19, 2013 | 03:18 AM
The Grumpiest
I guess me putting it into capital letters didn't tell him that it was a proper name?
Old Mar 19, 2013 | 05:38 AM
Wilka's Avatar
No I just didn't understand what it did, thanks vtecnician2.
Old Mar 19, 2013 | 05:39 AM
Wilka's Avatar
My hand isn't that steady otherwise I could lol. These screws look cheap and if I cut them would prob cause my map to leak and the screws break under the tq of threading them
Old Mar 19, 2013 | 05:44 AM
The Grumpiest
People. have we gotten that helpless? Take off the Missing Link. Mount the MAP sensor. Take a screw and thread it in until it doesn't thread anymore. Whatever length of thread left over (visible above the MAP to the screw head) is what you need to cut off from the end OR will tell you what length screw you need to buy.
As for being "cheap screws" they seem to have held both the MAP sensor and Missing Link on with no issues all this time.
Jeez.
Visionist
Apr 27, 2006 09:02 PM
97turboteg
Jan 1, 2006 02:09 PM
baybee_boy
Jul 22, 2005 11:43 AM
boostedcivicsir
Nov 18, 2003 01:15 PM
1fstevo
Sep 19, 2002 11:39 PM
