Transmission & Drivetrain Gearboxes, Differentials, Clutches
97 ls clutch pedal shaking and really bad vibration
Old Mar 17, 2013 | 07:50 PM
SwagNationEK9's Avatar
Icon2 97 ls clutch pedal shaking and really bad vibration
So i work at a delivery boy and i was driving today and the gps took me thru a really i mean really bumpy road. my struts are now completely blow from how bad the road was and now when i put my foot on the clutch pedal it shake alot.
when i start to go (from 1st gear) the whole car is jumpy and shaking alot.
when i cold started the car it would go into gear at all and i had to apply alot of pressure (like lifting a 50 pound weight amount of pressure) for it to go in gear.
i did some research some say clutch line, mounts, throw out bearing, or warped flywheels
I need help! please help me before it gets worst! thank you
Old Mar 18, 2013 | 10:42 AM
ActionClutch's Avatar
Default Re: 97 ls clutch pedal shaking and really bad vibration
does it do the same on reverse or any other gear?
Old Mar 19, 2013 | 07:25 AM
does it in all gears. and vibrates the most when im at a full stop
Old Mar 19, 2013 | 12:10 PM
Emeraldbomber's Avatar
Motor mount?
Old May 16, 2013 | 07:00 PM
AMCCPO's Avatar
What was your fix?
Old May 20, 2013 | 11:10 AM
found out the "meat" from the clutch on one of the pucks broke. got a new clutch nd where was no problem. it was probably because i didn't break the clutch in much.
brandynEG
May 29, 2014 01:57 AM
snzh22
Apr 29, 2008 09:22 AM
kyle5486
Jan 18, 2006 06:11 PM
turbotime
14
Oct 22, 2004 12:14 AM
93civcx
Jun 18, 2004 06:25 AM
