a/c help
Old Mar 17, 2013 | 07:06 PM
smilindave's Avatar
Icon2 a/c help
will a usdm b series a/c bracket fit my jdm b16. i want the a/c to work in my
91 crx. this is a budget build. i know about the hasport bracket. a/c did not
work b4 swap. please help. spouse not happy.
dave
Old Mar 18, 2013 | 12:01 PM
fcm's Avatar
fcm
Old Fart
Default Re: a/c help
Sorry not sure if it will fit or not, why not just try it?
If it does fit, and once compressor is installed, system flushed out, all the O rings replaced a new filter dryer is installed and everything connected together, with the R134a retrofit service ports installed, and the correct amount of oil, [ester oil] put into the system, you will need to take it to a shop and have them do a nitrogen pressure test on the system, 250PSI for at least 1hr, [the longer the better] to insure system is "airtight",
If it holds pressure the shop can do a proper evacuation, [sit on vacuum pump for 1 hr] then recharge with 80%-90% of R12 charge, with R134a. 94
SW20FL
Jun 25, 2015 04:47 AM
dmeconitas
Oct 3, 2009 12:07 PM
1990AccordEX
Sep 1, 2009 02:51 PM
maivla01
May 31, 2006 10:32 AM
drumminforev
Apr 3, 2006 06:27 PM
