ls vtec/sir ii/gsr/itr?
Old Oct 22, 2002 | 05:08 AM
Mr. Lonely JDM 4dr teg's Avatar
Default ls vtec/sir ii/gsr/itr?
ok i have a 94 integra ls. i just got 4000k to spend on my car. i dont no if i should go ls vtec w/ a sir first gen head, dis and etc.. or should i just do a sir ii, or gsr, or itr ful swap. what do you guys think i should do?
Old Oct 22, 2002 | 06:45 AM
Hooch'n's Avatar
Default Re: ls vtec/sir ii/gsr/itr? (94 Integra LS)
do what you like, ITR in my opinion would be best if N/A. GSR if plans to go turbo. I am not a big Ls vtec fan, the bigger displacement isn't that big of a deal....in addition to the fact u have to make sure it is done right/crank and what not can handle higher rpm's. Just .02$
Old Oct 22, 2002 | 03:42 PM
Default Re: ls vtec/sir ii/gsr/itr? (Hooch at 8400-RPM)
well all of these are going to be all motor. i was heard that lsvetc has alot of power, even enough to run 12-13 in 1/4 mile. the sir ii is cheap but iunno. i also heard that gsr fully built is as good or even more better then the ITR. i want to go ITR but also GSR. LSVTEC because it's way cheaper and i dont have to use 3000+ to buy an engine. So im still debting but thanks for the tip
hondaguyexsi
Mar 29, 2005 02:38 PM
Gsr_Hybrid_theory
Nov 4, 2004 09:18 PM
mr_mbuna
Sep 5, 2002 09:14 AM
ITR1071
Jun 16, 2002 10:13 PM
