EPERIENCED engine builders...what clearances are u guys running??
JE 9:1 comp. pistons with stock sleeves, stock bore B18C...what piston-to-wall clearances are u guys running for 300-400WHP applications? JE recommends .0040, but I wanted to know if i should go slightly looser or what...thnx guys...
[Modified by TheSwift1, 2:46 PM 10/22/2002]
Do exactly what JE recommends for your application. Too loose and you will be burning oil in 1000 miles..too tight and you will soon lose compression with piston black death.
the way you control is based on your bore of the motor. you usually need ot bore the motor to the spec of the piston. Some builders do it the opposite whihc in my opinion is ***.. You should never bore just a plain block with out having the piston with you.
That is way you can keep your piston to wall clearance in spec. Alwlays do the correct hone job with a good stone also helps the rings seat faster thereby no blowby
...too tight and you will soon lose compression with piston black death.
Could you explain what this is?
BLKCRX
Jul 24, 2002 03:40 AM
