Quick question: Need to replace radiator, what Honda models/yr can I pull one out of?
Old Mar 15, 2013 | 08:12 PM
Juans_MX3's Avatar
Default Quick question: Need to replace radiator, what Honda models/yr can I pull one out of?
Own a 95 Honda Civic EX (1.6L)
Radiator is starting to leak. I'm positive its the radiator and not the hose.
I just need to know what year and models Honda radiators will work with my 95 EX.
Thanks
Old Mar 15, 2013 | 08:34 PM
hwyix's Avatar
Default Re: Quick question: Need to replace radiator, what Honda models/yr can I pull one out
As a mechanic and then a shop owner, I will tell you the number one failure I see for a cheap part that cost a very expensive repair was a radiator going out.
I have replaced soooo many cracked/broken radiators I lost count. You might get lucky and see the steam and pull over in time to save your engine.
You lucky for your honda you can buy a ALL aluminum (no plastic end tanks) radiator.
grumblemarc recommend this place to me. I purchase from them. Had a small problem. I emailed them on the weekend and got a response back the same day!!! I recommend them also.
go-autoworks.com
If you just want your question answered you can probably go over to rock-auto or some other website and see which part numbers are the same for the different year civics.
Old Mar 15, 2013 | 09:07 PM
slowDB7's Avatar
92-00 civics, and i think del sols too
Old Mar 16, 2013 | 06:20 AM
Juans_MX3's Avatar
go-autoworks.com
Thanks for sending me that link. Someday when I buy a CRX or another Civic, I will keep that website in mind.
For now, this car is my daily driver and I need to fix the problem ASAP before Monday (school starts for me again). I will just go with a AutoZone radiator.
Thanks again
kkwick
Jun 17, 2009 03:08 PM
okay1234
Apr 11, 2006 05:41 PM
Stop the Beast
Mar 13, 2002 11:38 AM
