Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
how to check lca bushings
Old Mar 15, 2013 | 04:28 PM
dakota1820's Avatar
Default how to check lca bushings
The front bushings are what I am concerned with? How do you guys know when they are bad? Whats the best way to check them? All advice is appreciated.
Old Mar 15, 2013 | 05:37 PM
grumblemarc's Avatar
The Grumpiest
Default Re: how to check lca bushings
Look at them.
Old Mar 15, 2013 | 05:39 PM
dakota1820's Avatar
What am I looking for? A little more specific would be nice!
Old Mar 15, 2013 | 07:30 PM
m_shake's Avatar
Cracks, tears and overall deterioration.
Old Mar 15, 2013 | 07:36 PM
dakota1820's Avatar
So movement of the bushing isn't a factor? By the looks they look ok.
Old Mar 16, 2013 | 03:14 AM
dempsi's Avatar
The bushing can begin to look weathered on the exterior but still have a little life left.
The best way to check is to have the car on a drive on lift and use a pry bar in between the bushing and arm to see if and now much deflection you have.
BTW....how many miles are on the car and what is making you think they might be bad?
Old Mar 16, 2013 | 04:30 AM
dakota1820's Avatar
120,000 I was just doing routine checks and was wondering how you actually check these .
Old Mar 16, 2013 | 05:13 AM
lazlong's Avatar
Yes, movement is a factor. They'll kinda compress but, they shouldn't move.
Old Mar 16, 2013 | 05:33 AM
dakota1820's Avatar
So if I pry between subframe and control arm how much should it be able to move
Old Mar 16, 2013 | 06:01 AM
lazlong's Avatar
The LCA will move a little due to compression of the bushings. The bushings shouldn't move.
This one is real bad:
Do you hear it knocking too? A good one will make no noise and the LCA will barely move.
Old Mar 16, 2013 | 06:20 AM
dakota1820's Avatar
No knocking. They both moved a half inch or so. The control arm move that is.
Old Mar 16, 2013 | 11:29 AM
lazlong's Avatar
You should be alright for now. Check them again in a year or if the steering/suspension feels weird, whichever happens first.
Old Mar 16, 2013 | 11:31 AM
dakota1820's Avatar
So movement is ok I guess as long as you have that rubber tension feeling so it's a solid resistance and isn't just flopping around?
Old Mar 17, 2013 | 11:00 AM
It Wasn't Me's Avatar
You need new bushings if:
The LCA is just flopping around.
The rubber is cracked.
The rubber has pieces missing.
The rubber is missing all together.
You need piece of mind.
If they look okay, they're probably okay.
If you're worried about it, replace the bushings. They're cheap and are not terribly difficult to replace.
Old Mar 17, 2013 | 03:57 PM
04civicoupe's Avatar
i bought my car last year with 120k with alright bushings and now at 130k my bushings are worn badly. mine have been bad for awhile. pulling into my gfs driveway my right control arm makes clunking noises. Do you guys recommend just replacing with oem bushings or should i upgrade to polyurethane? Theyre not that much extra money but was wondering what you guys would do if you were me. (i dont care about ride comfort but occasionally like to push the ole civic)
Old Mar 17, 2013 | 04:10 PM
jdmatheart's Avatar
Glad i know what to look for now.. On another note, has ANYONE ever found or heard of aftermarket front LCA's for a civic??? God that would be nice if they are out there ive been wanting them for years.
Old Mar 17, 2013 | 05:56 PM
That's entirely up to you, really. If money isn't a concern, you could always look into a spherical bearing kit.
There are non-OEM front lower control arms available. Check Google and/or eBay.
Old Mar 18, 2013 | 12:22 PM
dakota1820's Avatar
Took a video of my driver side bushing movement . Is this to much play? If I go on gravel roads it'll make some noise . I guess this Is the noise anyway everything else is in good shape. This movement is with the car on the ground. It'll move more with the car lifted up .
Old Mar 18, 2013 | 12:24 PM
dakota1820's Avatar
Not sure why it posted the video 3 times I apologize for it.
If a mod can fix it that would be good I can't it keeps kicking me off every time I try
Old Mar 18, 2013 | 02:31 PM
The hell? When I try to edit that post, it will only let me edit the first sentence and the first video. It acts like the rest of the post (two videos and last sentence) aren't actually part of the post.
Very strange. Software glitch of some sort.
Edit: I've brought it to "their" attention.
Old Mar 18, 2013 | 04:24 PM
dakota1820's Avatar
Thank you "it wasnt me"
So is that to much play in the bushing?
Old Mar 18, 2013 | 04:35 PM
Oh, sorry, I hadn't even watched it. LOL!
Well, now that I have, I hear a lot of clunking along with so much glare I can't see what you're doing.
They're rubber. They're going to have some play in them if you pry on them hard enough.
If they're sloppy, replace them.
Everything else, re-read my first post. Determining whether or not they need to be replaced should be easy enough to do.
Oh! Yeah, it was a glitch. They're working on it. (the youtube incident)
Old Mar 18, 2013 | 05:53 PM
lazlong's Avatar
Poly bushings are a MUCH stiffer ride but, they pretty much last the life of the car.
Old Mar 18, 2013 | 09:33 PM
dakota1820's Avatar
http://imgur.com/CE7xZNg.jpg
Turning the wheel all the way and the cracks are clear as day. In the day time with the sun and the glare it was almost impossible for me to see .
Guess these are bad?
ragnarok0mega
Jul 11, 2009 08:51 PM
Scottyk6
Suspension & Brakes
Jan 17, 2008 04:08 PM
idriveadelsol7
10
Jun 24, 2005 06:43 PM
elpiar
Apr 29, 2005 11:26 PM
elpiar
Suspension & Brakes
Apr 28, 2005 07:45 AM
