anyone running H&R sport springs
not that much....
but they are good upgrades, progressive springs thatll make your daily commute and spirited driving
a good experience...
2-3" low than the stock height.... after it "seats" or settled over few hunderd miles...
theyre smaller, you probably wont need spring compressors. Its not the safest way, but instead of taking out my bolt style spring compressors to remove the old springs i just cut them.
Posted from Honda-tech.com App for Android
probably not, theyre spun pretty close to each other. Ive also done the use an impact and hide around the corner technique. Again, pretty unsafe, but it works.
i've been running h & R's for a few months an they are pretty nice. better than stock thats for sure.
i JUST pulled them off the crv to put on BWR full bodies and i have the H&R's up for sale now if anyone is interested. just PM me
is this the BWR Set you are using?
http://www.bwrusa.com/product_p/ss-hd07.htm
What else did you have to upgrade to run that setup? Also, How's it ride?
swap drop align and drive.
so you did not have to do any cutting or grinding with the BWRs? How does the drive feel? I've been eye-balling that set for a while now... Also, what size wheel/tire fits comfortably under there? I've got 17x8 Cragan Soft 8s but i have not gotten tires for them just yet..
I have just hear so many stories so far of grinding this and cutting that when it comes to the V. I just wanted to be sure about it. Could you post up a photo of how its sitting now?
Thanks a bunch, pal!
janz3n
Mar 23, 2007 04:27 PM
