What cams are the right ones to run
Old Mar 15, 2013 | 10:50 AM
crxin's Avatar
Default What cams are the right ones to run
Wanted to get some opinions on what cams people are running. Right now I have a mildly built ls-vtec. It is bore .20 over ls bottom end with b16 top end. Believe it is running 9.8 to 1 compression, b16 intake manifold and stock b16 exhaust manifold. I am running a 70mm skunk2 throttle bottle with short ram intake. In between the throttle bottle is the "polar bear racing" spacer plate which runs 70mm at throttle body side and tapers to 68 mm. The intake is port matched to the 68mm spacer, and is port matched with the intake manifold gasket and head. The exhaust manifold has also been port matched for the exhaust side of the head, and gasket. I am running an AEM fuel rail, blox fuel pressure regulator, and 370cc high impedance injectors. I have a chipped p28, map was done by "http://www.phearable.net/".
I am wondering what N/A cams would be a good fit for my build, and give me a little more.....any thoughts?
ef dino
Dec 9, 2007 12:24 PM
Hockey27925
Nov 2, 2005 01:51 PM
-Whitey-
10
Dec 27, 2002 12:30 PM
