installing ect.
Old Mar 15, 2013 | 12:05 AM
Manny-Em1's Avatar
Default installing ect.
b20v
i have a b20 block
11:5:1 compresion
84.5mm
head is stock all i have is dual valvesprings
whale *****
rage tri-y headers
stock exhaust
type r intake manifold
i recently purchased:
blox fpr
skunk2 stage3 cams and camgears
70mm throttle body
NOT TUNED ATM but i have obd1 chipped
i was wondering if i can install all of wat i bought atm but i wont be able to tune it probly till like 3-4months from now...
should i wait till i get it tuned to install all of that or can i install all of that without any problem
Old Mar 15, 2013 | 05:08 AM
jdm_rb20's Avatar
Default Re: installing ect.
wait till it's tuned. I have a friend trade me aftermarket parts and a chipped ecu for my stock parts. We installed, used a basemap (until I could get it tuned later), result: low idle = low oil pressure = spun bearing.
Old Mar 15, 2013 | 05:56 AM
kyden's Avatar
i hope your current setup is tuned as well. i would wait.
Old Mar 15, 2013 | 08:06 AM
Manny-Em1's Avatar
My current setup is not tuned...
Is there anything else u guys suggest I get
Sorry btw forgot to mention I bought retainers as well
Old Mar 15, 2013 | 09:41 AM
jdm_rb20's Avatar
If it's not tuned ATM, you should get a wideband o2 sensor and gauge so you can monitor your air fuel ratio.
Old Mar 18, 2013 | 12:53 PM
Manny-Em1's Avatar
Also I wanted to know if I should buy an apexi ws2 full exhaust system
Or should I buy only the exhaust and have someone make me custom pipping...
Right now I have my stock exhaust
Old Mar 18, 2013 | 01:02 PM
Brandon_ek's Avatar
Custom exhaust would be better , also here's my setup
Here's my bolt ons I have:
Aem 3" cai
Blackworks intake manifold
Hytech big tube headers*
Str throttle body
Hi flow cat 2.25*
P28 b20 vtec basemap*
Slim fan and rad*
Greddy catch can setup ported to valve cover
Blox coolant overflow tank
Yonaka stage3 clutch
Mishimoto fan switch*
Type r oil pump
Type r water pump
Heads stock and bottoms stock but to me stage 3 cams are all to extreme for your setup plus if your gonna build the head I'd build the block to I'd go
Head:
Super tech
Retainers, valves , valve springs,
Brian crower cams
Golden eagle cam gears
Rdx injectors
Aem fuel rail
Block:
Cp pistons
Manley rods
Acl bearings
Old Mar 18, 2013 | 06:24 PM
Manny-Em1's Avatar
Looks really clean bro...
I berly bought the supertech retainers but I have REV dual vaulve springs
Also they are selling me the golden eagle camgears but wasent sure if they are good
Also the shop is charging me $350 for magnaflow and custom pipping
But not really sure if I want the magnaflow muffler I really haven't seen them on honda...
Anyone know if those are good?
And witch should I stick with magnaflow or apexi
Old Mar 18, 2013 | 06:25 PM
Manny-Em1's Avatar
Also for I got the skunk2 stage 3 cams because I wasent sure witch ones to get since I didn't wanna just get any cheap ones... Do u think I did bad in getting them?
Old Mar 18, 2013 | 06:31 PM
Brandon_ek's Avatar
Go with the magnaflow and stage 3 is a little aggressive for your build try selling em and going with brian crower cams
Old Mar 18, 2013 | 06:56 PM
Manny-Em1's Avatar
Alright bro thanks a lot for the help...
Old Mar 18, 2013 | 06:59 PM
b19coupe's Avatar
Wait until you have all of your parts and are ready to tune. Patience is a virtue. If you get talked out of running those cams, I will take them off of your hands
Old Mar 19, 2013 | 01:49 PM
Manny-Em1's Avatar
Maybe lol... Also u guys know why wen I floor it a lot of white smoke comes out??
Old Mar 19, 2013 | 08:16 PM
DazeMS's Avatar
your turning water into mist, steam power ftw!
Old Mar 19, 2013 | 08:37 PM
Brandon_ek's Avatar
Your burning coolant ,
Whit smoke- coolants burning
Blue/greyish white- smoke oil burning
Old Mar 19, 2013 | 08:41 PM
DazeMS's Avatar
a CHOOOOOOOOO CHOOOOOO
oldmanTypeR
Mar 24, 2016 09:49 AM
RedEG91
Jul 29, 2009 12:29 AM
shitycivicsidekick
Oct 30, 2008 05:30 PM
lude98SH
Jun 29, 2006 07:54 PM
2000_Civic_Si
Mar 3, 2003 02:25 PM
