D16Z6 Possible Leaks?
Old Mar 14, 2013 | 08:18 PM
JPeezyasko92's Avatar
Icon3 D16Z6 Possible Leaks?
I think it's in the best benefit for D16Z6 engine equipped vehicle owners to start this new post on possible oil leaks (whether common or uncommon) a D series engine may have.
I'm curious to the fact that my D16Z6 is leaking but is a bit confused where it originates from. So if we can all generate a list of the seals, gaskets, and rings this engine has, that would be very helpful.
Old Mar 14, 2013 | 08:21 PM
Default Re: D16Z6 Possible Leaks?
To my knowledge, the seals And gaskets I know that could cause oil leaks are:
Valve cover gasket
Spark plug seal
Valve cover bolt seal
Dizzy O-ring
VTEC Solenoid Gasket
Internal Cam Seal
Front Cam Seal
Rear Man Seal
Old Mar 16, 2013 | 07:35 PM
J.C.B.'92civic's Avatar
Valve cover gasket
Spark plug seal
Dizzy O-ring
Internal Cam Seal
Front Cam Seal
Rear Man Seal
I have a D16Z6 as well and I'm having the same problem with mine. The motor has always run strong and smooth, and has been well maintained. Looking into doing a head job though this will be my first. Other than what my manual tells me, is there anything I should keep in mind when doing this?
Posted from Honda-tech.com App for Android
Old Mar 16, 2013 | 07:39 PM
also what is the best way to get everything as clean as possible? Might as well make 'er look pretty too.
Old Mar 16, 2013 | 07:56 PM
Former User's Avatar
Valve cover gasket
Spark plug seal
Dizzy O-ring
Internal Cam Seal
Front Cam Seal
Rear Man Seal
Also oil pan gasket, oil filter, oil pressure switch.
Old Mar 17, 2013 | 04:00 AM
delsolintegra's Avatar
My replacement D16Z6 has a leak around the oil drain plug. The threads don't seem stripped and I teflon tape them and use fresh replacement washers. I think the pan got dinged near the plug and it's a little deformed. Might have been a freak accident or maybe they're susceptible in this area to get bumped. I'm going to start using a little RTV to avoid the oil leaks in the driveway.
VTECwalka
Aug 23, 2012 03:13 PM
wernhersey
Feb 14, 2007 08:34 AM
speeddave
Canada (Sales)
Aug 6, 2005 02:26 PM
boostedcivichatchbacksi
Sep 11, 2004 12:40 AM
95turbohatch
May 10, 2004 11:13 PM
