coolant shooting up out of radiator while bleeding cooling system
Old Mar 14, 2013 | 06:26 PM
Randysi's Avatar
Default coolant shooting up out of radiator while bleeding cooling system
So I was just trying to get all the air out of my cooling system. (reason I believe there is air in there is because my idle is really bad/low. My car was driving fine yesterday (throwing map sensor code). affecting iacv?
well I had the cap off and turned the car on, cracked the bleeder valve. then closed it, waiting for the car to get up to temp so the thermostat would open. then all of a sudden coolant just starts shooting atleaat 5 inchs out of the radiator. Then I turn the car off and it dies down.
What is this a sign of? Ive never experienced this before.
Coolant appears to not be milky. same for oil.
Thank you to anyone that can help!
Old Mar 15, 2013 | 02:45 AM
TheOdditie's Avatar
Default Re: coolant shooting up out of radiator while bleeding cooling system
Milky is bad, milky means you have a busted head gasket allowing the oil and coolant to mix.
Old Mar 15, 2013 | 02:57 AM
grumblemarc's Avatar
The Grumpiest
Er. He said NOT milky. But I agree it's probably the HG.
Old Mar 15, 2013 | 03:48 AM
Randysi's Avatar
Thanks guys. I cant even pull out of my drive way without it stalling. And it idles really low.
Posted from Honda-tech.com App for Android
Old Mar 15, 2013 | 08:20 AM
festivagt's Avatar
Map sensor code can be anything from a vaccumm leak to a bad sensor. You could also have the map and tps sensors connected backwards too(same connectors and throws the code like that too). But water flying out of the radiator is probably the Head gasket letting compression leak into the cooling jacket - doesn't mix with the oil like that. Of course if the motor was hot and you just added water it could be boiling out.
Old Mar 16, 2013 | 07:20 AM
TheOdditie's Avatar
Ha! Thats what I get for trying to post first thing in the morning.
Old Mar 16, 2013 | 02:22 PM
neophish's Avatar
make sure the thermostat is in there the right way and that it is opening. and ultimately make sure you don't have some kinda blockage in the coolant system
StayKrafty
Jul 17, 2017 02:49 PM
ADIZZLE08
Honda Civic (2001 - 2005)
13
May 11, 2010 08:15 PM
dhn
23
Jan 5, 2008 01:06 AM
CDtegGo
Aug 27, 2006 02:22 PM
mz3bo
Feb 18, 2003 02:02 PM
