Best A/F meter for the money
Old Mar 14, 2013 | 12:34 PM
user 34938202's Avatar
Default Best A/F meter for the money
wondering what would be the best AF meter for the money. I ahve a Ef hatch with a high compression ls/v
Old Mar 14, 2013 | 12:38 PM
GhostAccord's Avatar
Default Re: Best A/F meter for the money
I am going to assume that you are looking for a wide band O2 sensor, controller and gauge setup. In that case, I would say PLX or Innovate Motorsports wold be the best bang for your buck.
Old Mar 14, 2013 | 12:54 PM
EsotericImage's Avatar
Retired Moderator
I heard all good things about the Innovate MTX-L and how its the fastest rate..And its only 159 shipped if you look around on ebay..
i think streetrays or streetside or street something was the seller.. been a few weeks since i looked it up.
Old Mar 14, 2013 | 12:56 PM
raverx3m's Avatar
I have mtx-l im not sure if new models are direct usb or still serial port but one i have still needs a serial to usb converter
Old Mar 14, 2013 | 01:04 PM
Retired Moderator
yea, still serial last time I checked
Only drawback is they use the Bosch 4.9 sensor which is better then the 4.2, but not as good as the NTK sensor.
Even the NGK Powerdex doesnt come with the NTK sensor in the box.. I find that quite odd.
Old Mar 15, 2013 | 01:08 PM
m_shake's Avatar
http://www.wbo2.com/home/products.htm is about the only place I can find that uses a lsu 4.9 sensor. Pretty much all others listed are the old lsu 4.2
Old Mar 15, 2013 | 03:51 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
X2 other than the streetray part. I avoid that company like the plague. They have horrible customer service and never responded to any messages I sent them. They actually blocked me from any purchases due to giving them a bad review. I only learned this after accidentally trying to make a purchase without looking at the seller. There are other companies on eBay with the same low price. I plan on ordering my mtx-l in a few weeks after months of research!
Old Mar 16, 2013 | 05:55 AM
Turbogixxer's Avatar
Always a fan of NGK AFX, but the PLX does work great too.
Old Mar 18, 2013 | 05:23 AM
thanks ive bought several things from streetrays with no issues
Old Mar 18, 2013 | 06:34 AM
mtber's Avatar
The innovate mtx-l works very well at a cheap price point.
Old Mar 21, 2013 | 08:34 AM
4potnick's Avatar
x2. can't beat the price
Old Mar 21, 2013 | 02:04 PM
Rtype16's Avatar
If you actually hook up the MTX-L either serial or through the analog output it only updates at 12 times a second. Just thought I would throw that out there.
Old Mar 21, 2013 | 03:45 PM
Spunkster's Avatar
Can't go wrong with any of hte PLX wideband kits.
Old Mar 21, 2013 | 04:11 PM
Black R's Avatar
25 Year Member
As opposed to USB?
Or you mean compared to the competition?
Old Mar 21, 2013 | 05:44 PM
Black R's Avatar
25 Year Member
Oh and how does the mtx-l compare to the lc-1?
Old Mar 26, 2013 | 05:35 PM
averyvm's Avatar
Had an LC-1 and I got some water in it and it took a crap on me so I just ordered the mix-l.
Old Mar 27, 2013 | 07:49 AM
Rtype16's Avatar
Originally Posted by Black R
As opposed to USB?
The MTX-L can't output faster than 12 times a second.
Old Mar 27, 2013 | 08:33 AM
Black R's Avatar
25 Year Member
What do you use / recommend?
Old Mar 27, 2013 | 02:22 PM
Rtype16's Avatar
I personally use AEM.
Old Mar 27, 2013 | 04:40 PM
Salami's Avatar
The output is used for data logging, correct? How fast is needed?
How fast is the AEM?
Old Mar 27, 2013 | 05:59 PM
OK so it sends it's samples 12 times/second, what's your point?
Is that not quick enough for tuning?.... So are you saying that the Bosch 4.2LSU sensor that they use in the EUGO is different from the one used in the innovate one?
Old Mar 28, 2013 | 07:54 AM
Rtype16's Avatar
It is not that it samples at 12 times a second(sensor). The output only gets updated at 12 times a second. Is it good enough for tuning maybe for some might not be for others.
The AEM is a live analog output. So whatever the sensor itself is sampling at the output gets updated at the same time.
So looking at a turbo K-Series Log as boost is ramping up starting at 4100 RPM 5.4psi in one second I get to 6500 with 18.5 psi.
Old Mar 28, 2013 | 09:07 AM
Testing I have read shows the AEM behind the Innovate for accuracy and latency.
Accuracy;
Innovate +/- .10 AFR
AEM +/- 1.00 AFR
Latency
Innovate = <100ms
AEM = <400ms
However, speed isn't always the key in sampling, specially if it has a full point probability of error.... I'll take accuracy over speed!
Are you able to share the source for your information on the AEM unit?
Old Mar 28, 2013 | 09:48 AM
Rtype16's Avatar
Your accuracy is way off Innovate and AEM are both +/- .1 AFR
Latency what exactly are you talking about and about which products?
The Innovate MTX-L & LM2 is significanty slower than the older Innovate units. The fastest it will be from 83ms to 120ms. There is no more instant mode on the MTX-L
The current generation of AEM Widebands are around 100ms.
Where the two differs is that AEM uses an analog output so it is a continuous output of what the sensor is reading. The MTX-L has a digital output so it takes the number and outputs a stepped value meaning it will give you the same reading until it sends out the next number.
Old Mar 28, 2013 | 09:56 AM
OK...I'm still working with my LC-1's, I think that is where we are bumping heads. I didn't realize the newer Innovate units were slower in processing and fully digital.
Little behind in the game I guess.
