Anyone have a S2k TB on their Lude?
Old Oct 21, 2002 | 10:22 PM
Que_Lude's Avatar
Default Anyone have a S2k TB on their Lude?
I have heard that it fits... Just want to make sure as I may want to go with an Ericks 68mm TB... $365 for that one though...
Old Oct 21, 2002 | 10:24 PM
TimeRacer's Avatar
Default Re: Anyone have a S2k TB on their Lude? (Que_Lude)
It fits, however you will have to do the coolant bypass mod with it. The ITR one also fits, same issue with the coolant however.
Old Oct 22, 2002 | 09:34 AM
Que_Lude's Avatar
Default Re: Anyone have a S2k TB on their Lude? (TimeRacer)
Which would you go with? S2K, ITR or Aftermarket 68-70mm? I'm N/A and plan to stay that way for now. IM upgrades probably next year as this is the initial start to the IM mod...
Old Oct 22, 2002 | 09:42 AM
Boostless97Lude
Guest
Posts: n/a
aftermarket 68-70
Old Oct 22, 2002 | 04:44 PM
TimeRacer's Avatar
I wouldn't do the TB until you also have the time/money to get the intake manifold ported (not extrude hone) and matched as well minimally. Along with the standard I/H/E. Otherwise it's just not worth it, since the intake manifold is a pretty large bottleneck on the H22A.
But if you do, aftermarket will yeild very minimal gains unless you're going to do some headwork. But also realize that you can also get a S2k or ITR throttle body a lot cheaper than buying a new Spoon, Erik's, etc TB.
[Modified by TimeRacer, 5:45 PM 10/22/2002]
Old Oct 22, 2002 | 05:20 PM
BoYgUaN's Avatar
it should fit with no probs
Old Oct 22, 2002 | 07:20 PM
Gangsta Accord's Avatar
it will fit just use a ITR gasket. and you can use the coolant lines that runs to it. im running a ITR one rite now and no problems just use the ITR gasket and plus on the s2000 throttle body you dont have the idle adjusting screw but on the ITR you do. so you mite wanna go ITR so you can adjust your idle
Old Oct 22, 2002 | 07:45 PM
Que_Lude's Avatar
Default Re: Anyone have a S2k TB on their Lude? (Gangsta Accord)
Thanks for all of the info! Now wheres the best place to get an ITR TB? Junkyard? New? Carparts.com?
Old Oct 22, 2002 | 07:49 PM
pitbull97's Avatar
whats up, I got a 5th gen, and Im thinking about the TB also, but what kind of gains do u think u could get with good head work and a TB, and porting the intake? I have all the other bolt ons, just curious.. let me know..
Old Oct 22, 2002 | 08:27 PM
piotrush's Avatar
Default Re: Anyone have a S2k TB on their Lude? (pitbull97)
would a s2k tb be compatible with a euro r intake mannifold?
gakkuken
Oct 20, 2004 09:18 PM
Shorty C
Apr 13, 2004 07:44 AM
93VTEChatch
Oct 18, 2003 05:58 PM
94gsr
Nov 1, 2001 05:10 PM
