Motor Mounts
Old Mar 13, 2013 | 02:19 AM
ATISTANG's Avatar
Default Motor Mounts
i'm sure this has been covered here over and over again, but i'm not coming up with much in the search
anyone have any experience with ebay motor mounts? I was going to go with Hard race but these are less than half the cost and money is tight right now. my car is relatively stock and is a DD
I was looking at this set
http://www.ebay.com/itm/1994-2001-AC...09e054&vxp=mtr
Old Mar 13, 2013 | 05:36 AM
kyden's Avatar
Default Re: Motor Mounts
they are oem replacement. there's not really much to say about it. you can probably find some good used oem ones for half that.
Old Mar 14, 2013 | 08:08 AM
hondamark35's Avatar
are you just looking for stiffer mounts or do you have broken ones that need replacing? or both?
there's another option if you don't mind a little DIY.
CRL/Somaca Hi-Viscosity Auto Glass Urethane Adhesive. the stuff is available on amazon for about $7 and one tube should do all of your mounts. use it to fill the open spaces in your mounts after cleaning and scuffing the rubber for good adhesion.
i did this with three of the five mounts on my civic. the responsiveness increase is noticable but the noise transmitted, especially while cruizing on the highway isn't bad at all. i can share more details, maybe even do a write up if you're interested.
Old Mar 15, 2013 | 01:37 AM
ATISTANG's Avatar
my mounts are shot, i just wanted to make sure these werent going to fall apart in 2 years
juanhda9
25
Feb 2, 2012 07:56 PM
barone
10
Aug 21, 2009 01:01 PM
jdmep
14
May 9, 2008 09:49 AM
numotive
Mar 4, 2007 10:52 AM
whitelightning
Nov 17, 2006 07:07 AM
