Fuse No.1 and cluster problem
Old Mar 12, 2013 | 11:48 PM
4everYoungCRX's Avatar
Default Fuse No.1 and cluster problem
My No.1 fuse (turn signal) keeps blowing, and my gauge cluster doesn't work. What could be the problem?
Old Mar 13, 2013 | 08:39 AM
jimmy o.'s Avatar
Default Re: Fuse No.1 and cluster problem
Either a short in the cluster or wiring my bet is the cluster try pulling it out and unplug the cluster and see if it pops the fuse without the cluster plugged in
Old Mar 13, 2013 | 10:03 PM
So I unplugged the cluster and the fuse still blew. I then unplugged the cluster harness completely and the fuse blew again! What else could be the problem? All my other fuses are fine.
Old Mar 14, 2013 | 02:35 AM
Gary Albano's Avatar
Does it pop as soon as you put the fuse in?
Old Mar 14, 2013 | 10:01 AM
No, it pops when I turn ignition key to II, just before engine start up. I think this is called IG1.
Old Mar 14, 2013 | 05:51 PM
jimmy o.'s Avatar
Something is shorting to ground in that circuit need get a diagram and start tracing wires
Old Mar 14, 2013 | 10:11 PM
I've narrowed it down to the main wire harness and the ignition switch.
Right now I'm testing continuity on the ignition switch per service manual instructions and I'm suppose to get continuity on WHT/RED + WHT/BLK + BLU/WHT, but instead I get 100 ~ 700 ohms. Could this possibly be causing my short?
WHT/RED = ACC
WHT/BLK = BAT-B
BLU/WHT = IG2-B
Old Mar 19, 2013 | 11:10 AM
I found the short. Wires leading to my front lights got exposed and touching the fender. All fixed now. thanks for the help.
Jaynik
Oct 27, 2010 05:12 PM
timntam
Feb 3, 2006 11:10 AM
JDMlyfestyle
Nov 20, 2005 07:21 PM
