Installing 99 Civic EX A/C into EM1
Old Mar 12, 2013 | 09:35 PM
eM1_kiD's Avatar
Default Installing 99 Civic EX A/C into EM1
hey guys, I am looking for some help. I bought a 2000 Civic Si back last June. it needed a lot of work and came with a D16Y8. it has been my project since then and for the most part I brought it back to it's stock form, besides the B series part. one of the main things I hated was that the previous owner took out the A/C and Power Steering and I am not looking forward to this year's heatwave and riding without A/C. anyways, I bought a whole and COMPLETE kit off a friend from his 99 Civic EX. anyways, long story short I was wondering if it was just plug and play and also when I decide to put in a B series motor would I have to exchange it out for another A/C. much appreciated, thanks.
Old Mar 12, 2013 | 11:27 PM
raidacaipo's Avatar
Default Re: Installing 99 Civic EX A/C into EM1
First you need to check to see if your have either a manual or power rack and pinion. You will need a power rack and pinion in order to use power steering. I dont want to get into details yet. Second, the a/c compressor from the Civic Ex will simply work with any B series swap as long as you have a bracket for it. Usually one from the older Crv will work.
Old Mar 14, 2013 | 12:47 AM
eM1_kiD's Avatar
I just bought the A/C kit complete. I am not a fan of power steering. I have the bracket it came with from that 99 EX, would that suffice?
Old Mar 14, 2013 | 01:45 AM
jbpnoman's Avatar
If the car has the D16Yx motor in it, yes, it will work.
Old Mar 14, 2013 | 11:30 PM
eM1_kiD's Avatar
okay, awesome. what about when I want to put a B series engine? ^
Old Mar 15, 2013 | 01:41 AM
jbpnoman's Avatar
You can make it continue to work with the CRV AC pump bracket.
Old Mar 17, 2013 | 11:34 PM
eM1_kiD's Avatar
okay, awesome. thank you. ^
Old Mar 18, 2013 | 12:12 AM
hufqnjhu's Avatar
Old Jun 18, 2013 | 01:51 PM
eM1_kiD's Avatar
really? so you did not need the B20 or Del Sol one? I am pretty sure I have the stock Si one installed, but I need to double check. if not, I have the D series one. I just don't want to go out and look for a B20 or Del Sol one to be honest.
Old Jun 19, 2013 | 05:28 AM
kyden's Avatar
if you have a d series in it, you need a d series bracket. when you decide to put a b series in it, you can use a crv bracket (if you are not using power steering) or a del sol vtec bracket.
Old Jun 20, 2013 | 11:36 AM
eM1_kiD's Avatar
oh, alright. well, I no longer have a D series in it and I do not have Power Steering. I am dropping in a B18b, so would I still have to use the CRV or Del Sol bracket?
Old Jun 20, 2013 | 11:44 AM
grumblemarc's Avatar
The Grumpiest
What part of
when you decide to put a b series in it, you can use a crv bracket or a del sol vtec bracket
is tripping you up? A B18B is a B-series is it not?
RVMIRXZem1
Aug 3, 2018 07:04 AM
jasony0630
Jan 4, 2008 01:56 PM
