AC Idler Pulley Bolt Stripped.
Old Mar 12, 2013 | 08:27 PM
Rover2cool's Avatar
Default AC Idler Pulley Bolt Stripped.
Hello I was changing my timing belt and needed to take off the AC idler pulley. And the center bolt is a little stripped. Is there another way of removing it? Anyone else have this problem? Thanks.
Old Mar 13, 2013 | 12:35 AM
mikekh10a's Avatar
Default Re: AC Idler Pulley Bolt Stripped.
my bolt snapped off, so part of it's been stuck there ever since
Old Mar 13, 2013 | 06:46 AM
strategy400's Avatar
Use a 6 point box end wrench or some vise grips and get a new bolt. Soak it first. If all else fails get a hacksaw or grinder in there and cut the bolt head off and remove the entire bracket. You might have to cut the head off, slide the pulley out a little and then cut the rest of the bolt behind the pully depending on what kind of clearance issues you run into.
You could also remove the entire compressor then main A/C bracket from the block. Might have to cut the belt.
WaryDriver
Aug 8, 2015 06:18 AM
EJ8mike
Oct 21, 2011 10:15 PM
Panoply
Aug 3, 2008 04:13 PM
Schultzie
Aug 5, 2007 07:44 PM
Gir
May 28, 2003 04:59 AM
