Quick Motor Mount Question
Old Mar 11, 2013 | 09:58 PM
Civ-dx-96's Avatar
Default Quick Motor Mount Question
I am doing a 00' gsr swap into my 96 civic dx (auto 2 manual as well) and ive found a 5 piece motor mount set on jhpusa.com, il put the link below so you can see what im talking about.
But besides the rear bracket (which im getting also) what else am im going to Havre to get if I were to get that 5 piece set and would I have any problems with these mounts in my swap because id rather not waiste the money on something that's notbgonna work-
Please let me know and heres the link
http://www.jhpusa.com/store/pc/viewP...idproduct=8869
Old Mar 11, 2013 | 10:27 PM
jdmem205's Avatar
Default Re: Quick Motor Mount Question
Don't forget your front trans bracket as well as del sol vtec ac bracket
Old Mar 11, 2013 | 10:50 PM
B_Swapped93's Avatar
X2^ seems like a good deal on the mounts
Old Mar 12, 2013 | 06:14 AM
kyden's Avatar
the mount kit you linked is not necessary for the swap.
Old Mar 12, 2013 | 06:19 AM
toto98coupe's Avatar
Hasport and innovative both sell billet mount kits for ur swap
I have a 98 civic coupe with a gsr swap I went with the innovative mounts in 70a
Old Mar 12, 2013 | 08:16 AM
Civ-dx-96's Avatar
http://www.innovativemounts.com/Prod...uctCode=B10051
Heres where I found the innovated mounts for 96-00 civ d or b series with hydralic tranny, would this be the set up im looking for minus rear bracket, ac. And tranny bracket.
Sorry just want to be 100% sure before I buy this
Old Mar 12, 2013 | 08:49 AM
dirty19's Avatar
Ridin Dirty in Cali
Dont forget you will still need to retain the torque mounts.
These three mounts dont go on the car alone.
Myth is that if you buy an aftermarket set that you dont need the torque mounts anymore.
Truth is you do!
Old Mar 12, 2013 | 11:16 AM
94EG8's Avatar
Seagull Management
The first set of mounts does not fit a '96 - '00 Civic. They're '92 - '95 Civic/'94 - '01 mounts.
That last set will work, although you could use OEM rubber mounts if you wanted to (this will require swapping the driver's side cast iron post mount bolted to the block with one from a '99 - '00 Si though)
As stated you will still need torque mounts.
Old Mar 12, 2013 | 11:55 AM
kyden's Avatar
^^ there's a drop down menu for 96-00 on there.
Old Mar 12, 2013 | 01:49 PM
Civ-dx-96's Avatar
Yeah as stated above there is a drop down menu on the first set thats why i started this but I still have almost all my parts from the d swap,
So...
Retain the torque mounts, get rear bracket ac bracket tranny bracket and those 3 mounts from the 2nd link I posted and all should be well?
Old Mar 12, 2013 | 01:51 PM
94EG8's Avatar
Seagull Management
basically yes, you'll also need the metal bracket for the front of the trans as well for the passenger's side torque mount.
atmosphere
15
Oct 7, 2025 03:53 PM
Bradshaw
Apr 26, 2012 08:44 PM
98savage
Apr 22, 2007 08:29 PM
dntbh8n
Apr 7, 2006 06:47 AM
Red_hatch
Jan 3, 2003 12:39 PM
