b16 all motor.. ideas to gain hp??
Old Mar 11, 2013 | 09:30 PM
odz-fab's Avatar
Default b16 all motor.. ideas to gain hp??
i recently built a b16 hi compression all motor... tuned at churches made 198hp. 91 oct. seems i have room for more.. looking for ideas on what to switch up. looking for serious input. i have alot to learn.
engine specs:
head b16 bowl matched and light porting
68mm throtlebody port matched
stainless dished valves. springs retainers
upgraded LMAs.
skunk2 pro 1 cams degreed
itr intake
98 jdm itr exhaust manifold
3in exhuast
b16a block
eagle rods
11:1 je pistons
96+oil pump
jdm b16 trans with quaf lsd
running s300 in a ef hatch.
suggestions on what my week points are that are holding back hp?
pics:
Old Mar 11, 2013 | 09:39 PM
B_Swapped93's Avatar
Default Re: b16 all motor.. ideas to gain hp??
Complent that high comp engine with a better header, ex PLM big tube tri-y, or other meant for high comp builds. Could mill the head a bit ? since you're running pro 1's get some adjustible cam gears you'll squize out a bit more HP. Aftermarket intake manifold is a good idea also w/port matched 70mm TB. better intake as well with v-stack. looks nice btw !
Old Mar 11, 2013 | 09:45 PM
odz-fab's Avatar
forgot to add i have cam gears.. yea i was think the stock b18c5 exhaust would be an upgrade for a 1.6 il try a different intake setup first.. maybe im expecting too much from a b16?
thanks for the input
Old Mar 11, 2013 | 09:53 PM
The header and intake manifold+intake are going to hold you back the most,(as they're still oem parts) that being said the best gain I notced was when I put a S2:im+70mm TB on my B18C1 way more top end.
I,H,E,IM,TB,Head milled,S2:T2's,chipped p28.<---94 GSR
Old Mar 11, 2013 | 09:57 PM
odz-fab's Avatar
ok cool! guess those are really the onlythings i can change out without pulling the valve cover
Old Mar 11, 2013 | 10:28 PM
rd91sib18c5r's Avatar
That seems pretty strong for a b16, have you taken it to a track?
Old Mar 11, 2013 | 10:59 PM
odz-fab's Avatar
drag strip? no .. the car setup is for roadcourse and autox
Old Mar 12, 2013 | 12:40 AM
jimmysxxl's Avatar
keep the intake/tb its not your bottleneck. Get a Toda Header (toda,plm,tegiwa etc) , Move your Breatherbox out of the way and get longer 3"ID Bend with a 3"Vstack. More Compression would be nice HG/Milling but only you know your p2v. Where did it peak with the pro1's ? what FD ?
Old Mar 12, 2013 | 12:54 AM
raverx3m's Avatar
v stack with 3.5 to 3 inch tapered intake tube would that gain any power in this engine?
Old Mar 12, 2013 | 01:04 AM
odz-fab's Avatar
hp peak?? about 8,400rpms it just kinda stayed at that till 9,500. yea the pistons stuck out the deck .015 and the head isnt fly cut so i had to run a .051 cometic to keep the outer rim of the piston from hittin the edge of the chamber on the head. thanks for the realistic input! v stack is something i should have done anyways and il source a header and go from ther
Old Mar 12, 2013 | 01:13 AM
vtec8200's Avatar
More power is always nice but a 4.9fd will give you better acceleration and improve your lap times especially with a 1.6l, in my opinion.
Old Mar 12, 2013 | 02:23 AM
jimmysxxl's Avatar
8400 peak on b16 seems kinda low and i can't see what bottlenecking it. as you stated get the header first and then try retarding cam timing a bit you might gain a few ponies up there.
Old Mar 12, 2013 | 03:42 AM
AaronEJ's Avatar
Please post your dyno chart. Would be intressting.
How are the cams degreed ? To stock skunk 2 specs or did you
Degree it on the dyno ?
Are the 198 whp or flywheel horsepower ??
Because 198whp at 8400rpm sounds pretty high.
Forget about changing intake manifold and throttlebody,
Because going any bigger, you will loose alot of bottom end power.
First thing i would do is a custom lentgh tuned 3" intake arm
With vstack.
And go for a toda header or a plm replica. Proven to make good power.
Old Mar 12, 2013 | 04:27 AM
jimmysxxl's Avatar
x2
Old Mar 12, 2013 | 11:54 AM
01DC4's Avatar
Put on a REAL Hytech Header!
Old Mar 12, 2013 | 03:19 PM
accorse07's Avatar
Nice Numbers...a bit high for what's been done but its Church's. How does the graph look?
Old Mar 12, 2013 | 03:23 PM
98vtec's Avatar
moderator emeritus
truth. The SKunk2 Ultra street manifold may be a good candidate for him as well.
btw, those pistons look awfully tall for only 11:1 compression!
Old Mar 12, 2013 | 04:40 PM
gsrturbo-ek's Avatar
nice build how much torque did it make?
Old Mar 14, 2013 | 07:22 AM
odz-fab's Avatar
i degread the cams during assembly to sk2 camcard but the dyno liked them alil more advanced.
the 3rd pull was best at 198 everything else we tried it wasnt liking as much
this dyno was the last pull with intake being retarded 2 degrees as we were searching for what it liked.we tried quit a few settings and i think he pulled off befor redline now that i remember as he knew it wasnt in a possative shift. that was our last pull. i reset the intake +2 and he reset the timing to what it was befor as well. but he printed the last pull instead of the best pull by mistake.
Old Mar 14, 2013 | 07:27 AM
odz-fab's Avatar
i agea with it being churches..hub dyno. its not about what one dyno said over another. its a tool to dial in your tune. simply looking for ideas to improve apon. most parts were used simply caus thats what i had on hand. not that i think they would best suit the build. im sure things need to be changed. i appriciat the knowledge and input!
Old Mar 14, 2013 | 07:32 AM
98vtec's Avatar
moderator emeritus
Im still trying to figure out how those tall pistons are only 11:1
Old Mar 14, 2013 | 07:33 AM
odz-fab's Avatar
aaronej your right the the redline was like 9,300 tq was 124
Old Mar 14, 2013 | 07:34 AM
odz-fab's Avatar
b16 having smaller stroke.. same piston in 1.8 is 12:1 roughly
Old Mar 14, 2013 | 09:15 AM
jimmysxxl's Avatar
lol it's way above 12:1 Anyway seems like Cams to me. Pro1's do around 190whp on an average B18C
89efhatchy
Apr 21, 2012 12:09 PM
blk_eg4
22
May 19, 2008 01:50 PM
Samuels
Jun 16, 2006 09:38 PM
C2Imports
38
Jun 6, 2005 11:57 AM
libila
17
May 16, 2004 03:33 PM
