4 wire o2 conversion for a 93 cx for a jdm b16a motor
dude are you using your stock engine harness? its the one with the single wire O2 sensor right? to make it easy for you just get any 92-95 civic ex wire harness, this is what i did and it fixed the problem
Are you asking if you can convert your B16A to use a 4-wire O2 sensor? ... or something?
[Modified by raene, 12:22 AM 10/22/2002]
your correct but i'll try this weekend to wire the o2 sensor if its not gonna work i'll just get the ex one but here it is
wiring for 4 wire o2
white-d14
light green-any grn/white wire on your engine harness...(its a ground)
black-a6
other black-any yellow/black wire on your engine harness its a power
what you guys think about that i will go this directly to the firewall and to ecu.. any doubts sure appriciated!
white-d14
black-a6
Just use your own wire and make a direct connection to the points at the ECU. That is the best way to do it. Route it through the grommet in the firewall just to the right of the. You will need to use shielded wire for 2 of the 4 wires.
civicmatt
Jun 22, 2003 07:27 PM
