car wont start
Old Mar 11, 2013 | 08:22 PM
bass man's Avatar
Default car wont start
So i got my buddies 2009 Acura tsx with a 4cyl (not sure what motor) and 71k miles so he said he was driving and the car just bogged out and died. So he got it towed over to my place and sure enough it cranks and cranks but wont fire at all. It has spark and i can hear the fuel pump turning on i pulled the line off the fuel rail and there is fuel at the rail.so it has spark and fuel so it should run The immobilizer light is going off like it should. I checked all fuses and relays and everything seems fine. Its almost like the timing is way off but i dont get how it could be the thing only has 70 k miles on it what a p.o.s. im outa ideas if anyone has any ideas i would appreciate it thanks
Old Mar 12, 2013 | 12:32 AM
holmesnmanny's Avatar
Default Re: car wont start
check for codes
Old Mar 12, 2013 | 09:39 AM
bass man's Avatar
No codes stored. Car also has injector pulse. The only light that came on he said was "check emissions"
Old Mar 12, 2013 | 10:26 PM
bass man's Avatar
Well tore into the motor today and found the timing chain slipped and guides were broken and all valves are bent. 2009 with just over 70k wow
Old Mar 12, 2013 | 10:54 PM
wow dude...is that thing still under warranty ?
Old Mar 14, 2013 | 08:16 PM
TurboDcTwo's Avatar
damn that sucks, invest in a compression tester if you dont already have one. good way to check if the timing belt had skipped or not, may cause lower compression in the cylnd.
Boosted_CRX_507
Oct 9, 2008 02:35 PM
VTEC_PRODUCTION
Apr 6, 2007 06:24 AM
accord-h22
Feb 13, 2007 04:45 PM
turbocivic0618
Nov 24, 2005 08:20 AM
krazie1
Oct 29, 2003 10:58 AM
