nasty cat rattle.....and NO it's not the heat shield!
Old Oct 21, 2002 | 09:32 PM
animated_life's Avatar
Default nasty cat rattle.....and NO it's not the heat shield!
my cat was rattling and i didn't have the springs that go on the front part of the cat where it connects with the header...so i got some and installed them...but the thing still rattles. looked at it some more and what's actually doing the rattling is the rear side of the cat where it connects up with the rest of the exhaust piping. the diameter of the pipe on the *** end of the cat looks to be (maybe) slightly smaller than the diameter of the rest of the following exhaust piping...so the cat vibrates up and down where it's supposed to meet with the cat-back piping. tried to beak the bolts loose at that connection point..but they're rusted/fused together. anyone else ever had a similar problem? or know what i should do about it? ....besides buying a new cat...
Old Oct 22, 2002 | 04:48 AM
Ruby Civic's Avatar
Default Re: nasty cat rattle.....and NO it's not the heat shield! (animated_life)
might have fractured the element inside the cat (the honeycomb crap)...
Old Oct 22, 2002 | 05:36 AM
Zer0DazE's Avatar
Default Re: nasty cat rattle.....and NO it's not the heat shield! (Ruby Civic)
or it could be that soft metal gasket (i dont know the real name) that goes betwwen them, may have baked. that will also cause a rattle. this happened to me.
Old Oct 22, 2002 | 07:57 AM
carolinaACCORD's Avatar
is the rear of the cat flanged or do you just have the outlet welded to the rest of the pipe?
*Post #600*
[Modified by carolinaACCORD, 11:57 AM 10/22/2002]
Old Oct 22, 2002 | 07:56 PM
Default Re: nasty cat rattle.....and NO it's not the heat shield! (PreloodDude)
ok i have pics now. this is the area that i am talking about. see where the pipe that comes out of the cat meets up with the rest of the exhaust piping....where the arrow is pointing. see the space there...you can't see ALL the space that is there...but you can get an idea. what do you guys think happened? think the "soft metal gasket" went crappy on me?
and here's the same thing from another angle....
[Modified by animated_life, 10:58 PM 10/22/2002]
Old Oct 23, 2002 | 09:23 PM
ttt
RTW DC2R
Mar 4, 2006 10:04 PM
Stellar1
Feb 19, 2003 05:24 PM
slowman
Jul 7, 2002 02:45 PM
