Brake fluid
Old Mar 11, 2013 | 05:20 PM
Andyxramirez's Avatar
Default Brake fluid
Hello ht.
I recently just filled up my brake fluid not knowing it was completely empty.
But why was it empty? Leak? Leaking from where tho? Possible places? Can brake fluid burn out?
Old Mar 11, 2013 | 05:39 PM
belairbrian's Avatar
Default Re: Brake fluid
As brakes wear the caliper pistons and/or wheel cylinders move out so brake fluid is transferred from the master cylinder. It could be that over the life of brake pads you could empty the master cylinder. would also depend on how full the MC was to start.
Old Mar 11, 2013 | 05:40 PM
delsolboi's Avatar
its probably the brake proportional valve leaking. Its right on firewall behind the intake manifold. You will see brake lines coming out of it. Mine is leaking too, and I'm replacing it.
Old Mar 11, 2013 | 05:56 PM
I'll have to check that out
strider2
Honda CR-V & Element
May 11, 2018 11:51 AM
770_dc2
Nov 7, 2010 12:42 AM
Chef Andre
Suspension & Brakes
Jul 22, 2010 08:22 PM
91integraLSVTEC
Jul 25, 2009 07:09 PM
spintboy
17
Jan 3, 2008 08:49 AM
