torque converter issue?
I have a 99 ex 4cylinder v-tec with 159k that i had purchased a couple months ago.
There isn't any issue with downshifts or upshifts.
But, when coming to a stop from any speed there is a lurch or bump in the trans when it downshifts into 1st.
When accelerating from a dead stop after the "bump", everything is fine.
But if you do a rolling start where you haven't stopped completely and the "bump" hasn't occurred and then give it gas to go, then it seems like it slips since it didn't shift into first.
I am sure i can just live with this characteristic, but is there something i can do besides getting a new torque converter?
I had a simular problem with my 2000! but it wasn't torque converter it was the shift solenoid, not shifting down until fully stopped, then clunking in to first! I got my first gear solenoid replaced and have been fine since!
If these are shift solenoids B and C they go for about $40 each. They can be replaced individually. There are also clutch pressure solenoids and lock up solenoids; their prices are much higher, around 200 to 250.
When my trans is acting up I also get this "clunk" when coming to a full stop, it's like it doesn't want to shift back down to 1st gear. Although whenever this happens I also get the rough shifting everywhere from 1-2, 2-3 and upwards.
Like mister two said the solenoids are cheap! Mine was $56 after tax! Ya the clutch pressure solenoid is not reasonable I had to replace second gear clutch pressure solenoid I was lucky to find good used one and that still costed me 185 before tax!
