Transmission & Drivetrain Gearboxes, Differentials, Clutches
flatten an exedy flywheel?
Old Mar 11, 2013 | 12:27 PM
maxogsr's Avatar
Default flatten an exedy flywheel?
Can an exedy performance flywheel be flatten/level? It s a 9lbs iron one... I Hope its the right term in anglish! Otherwise correct me!
Old Mar 12, 2013 | 06:12 AM
94EG8's Avatar
Seagull Management
Default Re: flatten an exedy flywheel?
I believe the term you're looking for is resurfaced.
If the friction surface is removable then probably not, if it's all one piece you should be able to.
Old Mar 12, 2013 | 06:23 AM
GagnarTheUnruly's Avatar
The exedy flywheels are 1-piece and are resurfaceable (within specified limits).
Old Mar 12, 2013 | 12:10 PM
Gearspeed-Performance's Avatar
^^ Agree
Old Mar 13, 2013 | 11:03 AM
ActionClutch's Avatar
Hello
We are Action Clutch Inc. Located in Los Angeles, we have been specializing in Clutches for over 50 years
the answer to your question is YES, you can resurface your flywheel
Bowl_of_Rice
Jan 12, 2012 07:41 PM
immalooser
Oct 18, 2005 08:08 PM
b16a27
Nov 5, 2004 04:43 PM
Rocks
Aug 23, 2004 12:27 PM
twitchm80
Oct 4, 2002 09:17 AM
