bottom end gasket kit: can anyone ID this huge o-ring?
Old Mar 11, 2013 | 11:14 AM
crxguy406's Avatar
Default bottom end gasket kit: can anyone ID this huge o-ring?
I've identified and used every item in this D-series bottom end kit, except for the large o-ring.
At first I thought it was for the oil cooler which some engines had, but it's way too big to be that.
Anyone know what it was for?
Old Mar 11, 2013 | 11:46 AM
g.r.crx's Avatar
Default Re: bottom end gasket kit: can anyone ID this huge o-ring?
water pump?
Old Mar 11, 2013 | 12:42 PM
jimmy o.'s Avatar
Yeah what he said^
Isn't it supposed to be formed tho lol
Old Mar 11, 2013 | 12:45 PM
crxguy406's Avatar
Nope, definitely not the water pump.
Old Mar 11, 2013 | 01:12 PM
jimmy o.'s Avatar
Well then your kit is missing a water pump gasket and I have no idea what that is XD
I looked up fail pros conversion set seems to have the water pump gasket and timing cover gasket but only one of the water pipe o rings I'd look at oem Honda parts diagram to see if that gasket is present somewhere but I doubt it never seem that in any of the d series engines ive taken apart
Old Mar 11, 2013 | 01:47 PM
crxguy406's Avatar
I'm not missing the water pump gasket, it was in the box with the new water pump itself.
I already looked at the honda parts diagrams for several different year/versions of D series motors and haven't found anything that looks like that o-ring.
I've always hated having parts left over, but I think it's the simple fact of not knowing what it's for which bothers me the most.
Old Mar 11, 2013 | 02:25 PM
jimmy o.'s Avatar
I looked at a couple of the gasket sets on ebay look about the same but a full gasket set should have a water pump gasket regardless if what you bought came with a new waste pump Imo
Old Mar 11, 2013 | 02:39 PM
jimmy o.'s Avatar
Here is just the conversion set very similar to what you have there and the conversion set most of time includes a water pump gasket
http://item.mobileweb.ebay.com/viewi...id=12024620466
Here is fel pros conversion set notice a water pump gasket
http://www.amazon.com/gp/aw/d/B000C2...dir_mdp_mobile
Old Mar 11, 2013 | 03:42 PM
crxguy406's Avatar
ohhhh so basically its just a cheap water pump seal that you form to fit.
mystery solved!
Old Mar 11, 2013 | 04:01 PM
ef yu's Avatar
Off topic, but Ive been on your build thread and damn it looks good. I hope you can make that generic gasket you are using to seal better than what i had. (i bought some off ebay) didnt last too long. probably 25-30k.
My HG went too. The leak came from between the cylinders. sucked but i sure learned that you cant buy good quality with cheap prices. Unless youre getting whole seller price...
cstap
Oct 10, 2013 06:34 AM
hondmywrld
Aug 29, 2007 11:14 PM
arielb1
Jul 17, 2007 09:13 AM
DougNuts
Apr 1, 2005 05:26 AM
CrazyKoreanCrx
Aug 23, 2004 01:55 PM
