del sol or integra parts for a b16a motor?
hi just doing a b16a swap and wanna replace some parts.. just wondering do i order the water pump,timing belt, clutch etc for a del sol or for an integra? my engine is from a teg xsi freont cut but im not sure?
cheers..
also for a clutch would a heavy duty clutch be sufficient and would a 3 puck brass button result in breakin driveshafts etc if i dump it? i want a good clutch but not at the expensoe of driveability
cheers
cheers..
cheers
Water pump & timing belt from Del Sol VTEC or 99-00 Civic Si.
Clutch depends on which tranny you have. I'm not positive, but I think that the 92 GSR clutch is the right one for a S1 tranny.
The only way you're going to break driveshafts is if you really build the motor (go built LSVTEC/CRVTEC or add 10+ lb of boost. Hi rpm clutch dumps probably won't break axles, but they certainly aren't good for the car/engine/tranny.
Eric
Eric
http://b16a.honda-perf.org/care.html ...belts from a del sol....cap and rotor from a 90-91 integ.....for a clutch...you dont need more than a street disc for daily driving if you are goin all motor but if your boosting you dont need more than a 6puck.....a 3 puck is overkill
thanks for that guys...
regarding the clutch.. i have a s1 tranny but we didnt get b16a integras down here in australia we only got the 1.8l non vtec.. so would that be the clutch im after? the one outta the 1.8l ??
cheers
cheers
all b series trannies should fit and be able to use any of their clutches(hydro different from cable)
s1, j1, y1 etc
also a list for you
Part Part Number
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orfice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Pump O ring (Does not come with Pump) 91302-PF0-003 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Bitch Pin Shift Linkage 91 crx si
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Valve Cover Gasket 12341-PR3-000 94 - del sol
V-TEC solenoid valve filter O ring 15825-P08-005 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose (trim) need a c clamp 19501-PR3-000 92 - integra gsr
Lower Radiator Hose (trim) need a c clamp 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
[Modified by RaVeN, 5:48 AM 10/23/2002]
s1, j1, y1 etc
also a list for you
Part Part Number
grlracer97
May 5, 2005 09:48 PM
civictech22
Aug 17, 2004 03:49 PM
