Distributor Timing?
Old Mar 11, 2013 | 09:57 AM
Pancho2193's Avatar
Default Distributor Timing?
SO I got a Obd0 Distributor from a 1990 SI CIVIC, and I got it on my car but the car is acting really strange, its making a weird sucking noise from the intake, and it bogs really bad when I give it any type of acceleration? Do you think I should cut the dizzy a little more so I can adjust the timing more or wtf do i do o.0? It was working fine with the other distributor
D15b VTEC Obd0 1988 Civic DX MPFI
Old Mar 11, 2013 | 01:20 PM
accorse07's Avatar
Default Re: Distributor Timing?
Why did you change out your Dizzy if it was working fine?
When you did change it out...did you happen to use a timing light and make sure your timing was correct?
Old Mar 13, 2013 | 05:15 PM
Eastcoastctr's Avatar
Did you get to the bottom if this problem? I'm having the same issue, I have a CEL 8 (tdc)
Sensor)
Old Mar 13, 2013 | 07:16 PM
Pancho2193's Avatar
Okay just got to the bottom of this, The OBD0 Distributor has to be custom made to advance more because the rotor is a bit off, so you have to make some kind of bracket to make it so you can advance prolly a good 2 inches more so you can time it correctly
Old Mar 15, 2013 | 09:38 AM
That doesn't sound right.. My engine was doing the exact same as yours. I tried switching the plugs to the TPS and the MAP, it fixed my issue. I had them backwards
Old Mar 15, 2013 | 10:57 PM
Pancho2193's Avatar
Yeah I made sure they were in the right spot, but it seems that my obd0 dizzy just isn't the right fit so it has to be advanced beyond the built in leg brackets, so I cut them off and made a custom bracket so i can advance it accordingly
MastaFlyMason
Oct 2, 2016 02:53 PM
ek fan
Jul 4, 2008 04:47 AM
xDicktonesx
May 19, 2005 07:05 PM
Hybrid Invasion
Mar 31, 2003 02:35 PM
philipkrotch
Jan 23, 2003 10:40 AM
