koni shocks
Old Oct 21, 2002 | 09:07 PM
zcpowereddx's Avatar
Default koni shocks
hey guys whats up I just bought a pair of good cond used shocks but the guy didnt tell me how to adj them so do I turn the *** clockwise to stiffen them up or counter clockwise also for drag racing do you guys run them all the way stiff or do you just play around with them at the track to see what works best
Old Oct 22, 2002 | 01:01 AM
carsaregood's Avatar
Default Re: koni shocks (zcpowereddx)
it should say on the **** which direction to turn. mine say clockwise to stiffen, anti-clockwise to soften.
Old Oct 22, 2002 | 01:45 AM
Crxer's Avatar
Default Re: koni shocks (carsaregood)
for daily driving i got the front on full hard and the rear on 1 less full turn than hardest. its a little rough but not too hard. i dont drag race. if you put front and rear on the hardest, it will probably be too rough, my hatch makes alota noise. just play around with it, theyre really easy to adjust
Old Oct 22, 2002 | 04:00 AM
keithv's Avatar
Default Re: koni shocks (Crxer)
for a drag setup, you will want the front soft and the rear stiff. this way you get less weight transfer off the drive wheels.
Old Oct 22, 2002 | 09:38 AM
cyberx's Avatar
Default Re: koni shocks (breaka_1_9)
what about if you want it to handle???? do u put it on hard or soft, wich side, back or front, or both, or do i but it all in the middle??
Old Oct 22, 2002 | 10:33 AM
keithv's Avatar
Default Re: koni shocks (cyberx)
you need to find the right adjustment for you car by playing with it.
for most hondas, though, the front will be set softer than the rear so the car can rotate.
Old Oct 22, 2002 | 01:52 PM
freud's Avatar
I'd be careful of that statement leaving it so open. There is a point you do not want the shocks to be too stiff on the rebound. In a slalom type situation or just over a series of nasty bumps it can cause your suspension to jack down to a point where you bottom out the suspension travel which could lead to your rear end to swing out uncontrollably fast.
Old Oct 22, 2002 | 09:14 PM
okay guys hanks for the comment I figured it out mine didnt come with **** so I turned it counter clockwise and bounced on the rear and it didnt move then I turned all the way clockwise and it bounced so that means clockwise is soft and counter clockwise is stiff
Old Oct 23, 2002 | 04:52 AM
keithv's Avatar
Default Re: koni shocks (freud)
well that is why i originally said you need to play with the suspension in order to find <u>your</u> right combination...
90daluv
Suspension & Brakes
Aug 10, 2013 09:00 PM
EF8 D-UNIT
Suspension & Brakes
May 30, 2006 12:01 PM
tinkerbell
Feb 12, 2004 03:40 PM
hybridEj6
Jan 16, 2004 12:09 AM
