How do you call that white stuff that sticks the plastic sheet inside the door ?
Old Mar 10, 2013 | 03:47 PM
RACEPAK's Avatar
Default How do you call that white stuff that sticks the plastic sheet inside the door ?
hey everyone,
i'm rebuilding a 1989 wagon and i want to completely remove the white rubbery stuff that holds the door plastic weather thing inside the door molds/trims?
i got most of it off with a razor blade but i want to remove everything before i give it to the paint shop,
thanks
Old Mar 10, 2013 | 04:13 PM
PanchoEK's Avatar
Default Re: How do you call that white stuff that sticks the plastic sheet inside the door ?
are you referring to the adhesion that holds part 3/8 to the door??
if you i think its called Beutel Tape.. as far as removing, you can try some adhesion remover.. good luck
Old Mar 10, 2013 | 08:52 PM
ThePunisherPnc's Avatar
plastic? lol
Old Mar 11, 2013 | 01:59 PM
RACEPAK's Avatar
nylon plastic, whatever.
yes PanchoEK, i'm talking about that,
thanks
Old Mar 11, 2013 | 03:29 PM
gorillafart's Avatar
i call it, HYPERACTIVE THERMOEUROPOLYETHELENE PLASTIC SHEETING 5.1
-DC2-
17
Nov 25, 2003 04:38 PM
Understeer
Aug 22, 2003 11:15 PM
Ideal
Oct 2, 2002 03:29 PM
