Safest boost PSI for stock ZC?
Old Oct 21, 2002 | 08:30 PM
1990hondaHF's Avatar
Default Safest boost PSI for stock ZC?
I'm getting all the info I can about turbos BEFORE I install this thing. So, what is the safest boost I can run on a stock ZC? Yeh, yeh, no boost is the safest, that's not what I'm asking. At what point do things start braking? What is a resonable boost level for a daily driver that I want to last a while?
Old Oct 21, 2002 | 09:11 PM
T-sohctec's Avatar
Default Re: Safest boost PSI for stock ZC? (1990hondaHF)
atmospheric.
j/k
you should be able to safely pull 6-8 lbs without any probs
Old Oct 21, 2002 | 09:29 PM
Default Re: Safest boost PSI for stock ZC? (T-sohctec)
Thanks.
Old Oct 21, 2002 | 10:23 PM
Drew Peacock's Avatar
6-7 psi if just using an fmu, your biggest gaurantee for reliability is tuning good tuning.
Old Oct 22, 2002 | 07:54 AM
Default Re: Safest boost PSI for stock ZC? (turbozxi)
I think I'm going with the SMC. Would that make a difference?
Old Oct 22, 2002 | 08:18 AM
RGAZ's Avatar
New User
You could run the 9-10 psi with the SMC, but I would stay in the 7psi range if you want reliability. As a matter of fact, with the SMC available, I would never recomend a FMU again.
Randy
BTW-Look for Bryson on this forum, he has a turbo ZC in a CRX.
h22_crx
Oct 24, 2005 07:19 PM
grover
Sep 11, 2004 01:49 PM
miniturbo
Jan 2, 2004 08:25 PM
