lsv question
Old Mar 9, 2013 | 04:43 PM
sh!ft's Avatar
Who the fack changed my title?!
Default lsv question
what would cause the motor to throw codes 9 and 8 and idle low at 250-ish rpm after a new fan switch was installed(one on t stat housing)?
have no idea what it could be. anyone got any info?
Old Mar 9, 2013 | 07:46 PM
xtremescouts's Avatar
Default Re: lsv question
Check the ground on the tstat housing. Maybe move it to the block side of the tstat housing and not the outlet side(the removable side). I bet it got knocked loose in the process or for what ever reason it just isnt getting the ground signal that the ecu needs now. If thats not it maybe check dizzy plugs to see if ones a little loose. If thats not the case try unplugging the fan switch to see if it affects it at all.
Just a couple thoughts for you. Hope it helps.
Old Mar 9, 2013 | 08:02 PM
sh!ft's Avatar
k ill check that stuff out when i get the chance
jojo ethan
Mar 13, 2011 01:47 PM
hybridclassic626
Sep 15, 2007 05:49 PM
Integrity 19
Jul 7, 2005 02:44 PM
wsiracerz
Jun 7, 2004 01:59 PM
TechNetOk
Jan 9, 2004 11:29 AM
