Del Sol Engine swap need help please
Old Mar 9, 2013 | 08:13 AM
killakush21's Avatar
Icon2 Del Sol Engine swap need help please
So im looking into swapping in a new engine for my 94' honda del sol s, i'm pretty new to cars even though my friends been helping me out Im looking for some answers, so first off i was wondering if and how much of a pain in the *** it would be to put in a H23a engine and what transmission would work well with it or should i just go the cheaper and easier side of putting a B16a3? and what kind of other parts id need for putting a B16a3 in thanks
Old Mar 9, 2013 | 08:29 AM
DC2RHDITRCLONE's Avatar
Default Re: Del Sol Engine swap need help please
first off del sol has its own shift linkage when doing a b-swap you would want to find one out of a del sol and depending on what available to you the h-series may be cheaper and just as easy to find parts you may need to be patient.
Old Mar 9, 2013 | 09:12 AM
gzes's Avatar
Id do b16 it is easy just drop riht in and get the b16 linkage from a del sol and the ecu and your good
Old Mar 9, 2013 | 09:57 AM
S2BumpsticksGSR's Avatar
Go ahead and waste $ on a b16 when a b18c has more to start with and revs just as high and bolts wherever a b16 does
Old Mar 9, 2013 | 10:20 AM
So if i go with the H series do i need an H series transmission? im assuming ill need to upgrade my suspension as well?
Old Mar 9, 2013 | 11:32 AM
jbpnoman's Avatar
The suspension is a supporting mod - it isn't required, but it's highly recommended.
For an H swap, you'll either need to run an H transmission and hack the everliving **** out of your chassis, or get an H2B adapter and run that way. I'm going to second an LS or GSR motor.
94delsol6428
20
Oct 2, 2012 07:10 PM
los_08
Feb 17, 2010 11:07 AM
nonvtecD
Jul 19, 2006 04:25 AM
R34_Del_Slo
Apr 15, 2004 05:26 PM
