window off track
Old Oct 21, 2002 | 08:12 PM
crxhfpower123's Avatar
Default window off track
how do i fix a window that got off track
any help is apprieciated thanks
Old Oct 21, 2002 | 08:19 PM
incubus's Avatar
Default Re: window off track (crxhfpower123)
u have to start by taking off your door panel, this will expose the arms that your window runs on, if you roll your window all the way down you can see the rear payne bolt thru a opening in the door frame, loosen the bolt, slide it out of the arm rest and put the widow payne back in between the felt seals, put the bolt back in the arm rest and tighten it back. hope this answers ur question, if u need more help just post more questions, but try to be as descriptive as possible cause I am not sure if I understand what u were asking.
Old Oct 21, 2002 | 08:25 PM
bryant's Avatar
Default Re: window off track (incubus)
samething happen to me, ewasy fix
Old Oct 22, 2002 | 07:20 AM
keithv's Avatar
Default Re: window off track (CR-X)
my el cheapo haynes manaul actually had some good pics to follow to get the window back on track. too bad the plastic piece that the window sits in was messed up! epoxy fixed that though...
Andyxramirez
Mar 14, 2013 07:20 PM
sleepyhead87
13
Jan 1, 2010 10:48 PM
whatan00b
Aug 19, 2007 01:04 PM
5lugSlug
12
Jul 28, 2005 09:02 AM
EnKidu
Oct 10, 2004 06:43 PM
