My car shut off after I slammed on the brakes
Old Mar 8, 2013 | 09:15 PM
KevinVX's Avatar
Default My car shut off after I slammed on the brakes
Hello everyone, I was driving on the freeway today and slammed on my brakes because traffic stopped out of nowhere. I noticed that my car had turned off and that it was still moving at about 20 mph and I had to turn it back on. Is this normal? I drive a 1995 Civic VX hatchback.
Old Mar 8, 2013 | 10:08 PM
jbpnoman's Avatar
Default Re: My car shut off after I slammed on the brakes
Auto, or manual? I wouldn't call it normal, but I could see a sudden deceleration causing a stall, if it's a manual. Probably not what happened, but for lack of a better alternative
Old Mar 8, 2013 | 10:33 PM
KevinVX's Avatar
My car has a manual transmission. I wouldn't call it normal either but, I just wanted to know if this is what is supposed to happen in a situation like the one that I described.
Old Mar 8, 2013 | 11:21 PM
jbpnoman's Avatar
No, it's not supposed to happen. To be honest, as long as the CEL isn't on after your fiasco, I wouldn't worry about it. It's probably a one-off event. I tried replicating it a few times in the parking lot before I went to get some cigarettes, as well as on an empty dead-end road, and couldn't.
Old Mar 9, 2013 | 06:02 AM
98typerar's Avatar
yea hopefully it's a one off I had one of those events the other day where my car wouldn't start then started up a few minutes later like nothing happened... didn't do anything out of the normal before I shut the car off and tried to recreate the day and hasn't happened since so it could.be a fluke thing.. ps if anybody has an idea what might of happened to me I would love inputs
Posted from Honda-tech.com App for Android
Old Mar 9, 2013 | 06:56 AM
joey56223's Avatar
check all of your plug wires and coil pack wire! i had a loose wire once going from my coil pack to my cap on my distributor and every time i did hard sudden movements the car would die because it wasnt getting spark to the plugs!! could be the problem
Old Mar 9, 2013 | 07:30 AM
mitchh29's Avatar
My car randomly shut off while pulling into work yesterday. Im thinking it was a fluke also because it was all rainy/snowy and doesnt like to run well in that weather
Old Mar 9, 2013 | 07:37 AM
Eddie's Avatar
Master Ninja
My guess is that you just stalled. You probably didn't notice because your were busy trying to stop.
Old Mar 9, 2013 | 10:05 AM
crazyhouse2011's Avatar
IF YOU HAVE POWER BRAKES YOU MIGHT HAVE DRAWN TOO MUCH VACUUM AND KILLED THE ENGINE. EVERY TIME I STOMP ON THE BRAKE PEDAL WHILE STATIONARY MY REVS DROP A COUPLE HUNDRED. MAYBE YOU STOMPED SO HARD THAT YOU DROPPED LIKE 8 OR 9 HUNDRED REVS AND THE CAR DIED? BUT A FORCE LIKE THAT WOULD REQUIRE YOU STOMPING THROUGH THE FLOORPAN, SO I'M NOT SURE ABOUT THIS.
Old Mar 9, 2013 | 01:22 PM
KevinVX's Avatar
This part had me in tears. The revs do drop slightly if I apply the brakes while I am stationary but, I don't think it would be enough to cause the car to turn off. I am guessing that I stalled by accident due to being preoccupied. When I tried to replicate the incident, my car didn't turn off because I stepped on the gas right after.
slammedobd1teg
Suspension & Brakes
May 29, 2010 07:38 AM
eg_ruoner364
Jun 18, 2008 12:04 PM
AccordDemon
Oct 27, 2005 01:21 PM
Neren
19
Jul 16, 2005 03:19 AM
i20ar
Nov 2, 2004 03:47 AM
