96 civic coupe ex leaning
Has your car ever been in an accident? hit a deer? any evidence up front of being hacked back together so to speak?
Ive been really searching through the front of my car and come to realize that the one of the previous owners must have replaced the radiator suport, not strait, causing a very weird stance.
Nope not at all, it was hit in the rear but the odd thing is. It's an ex so when I bought it, I didn't think much of it and it has drums in the back, not discs. The trailing arms have numbers from like a salvage yard
That is strange, but weird things happen in accidents, it could have been caused by getting hit in the rear twisting the whole car, dapending on how it all happened.
Is their any aftermarket suspension parts up front?
When I bought the car it had stock suspension on it, I put my old skunk2 springs and shocks on the car hoping to fix this but such luck. Isn't there a machine that can straighten out a unibody car for things like this?
Yes there is, its a very expensive process, and not all body shops have the capability so you'd have to call around to find a shop that does it. I worked at a shop back in washington that did that, it only got used once in the whole year that i worked there, but is a very cool process.
OMG!! Yes! Worn bushings can cause this. At this age your ca probably does lean to one side. If you have adjustable coilovers then adjust them so the lean isn't there. If not then learn to live with it. I doubt HIGHLY your frame is bent.
BTW EX have drums in the rear. Don't know where you thought it was discs.
Make up your mind. The bushings are blown or are they new? And if all you put on were lowering springs then that could ALSO make your car lean which is why I do not recommend lowering springs. Posts like yours reinforce this fact time and time again.
rexracer07
Apr 25, 2004 11:41 AM
