sometimes car wont start after a 10-15 drive
Old Mar 8, 2013 | 02:48 PM
omgwtf's Avatar
Default sometimes car wont start after a 10-15 drive
when i drive for a while and turn off the engine, come back to the car to start it up. it starts up and die. then i have to wait for 1min and start it back up and it starts just fine?
i was thinking it could be fuel pump? or fuel related?
*** a while back i swap out my z6 motor to my orignal dx motor, it was doing the same thing to the dx motor too..*** swap back my z6 in, and still doing it...
Old Mar 8, 2013 | 02:49 PM
omgwtf's Avatar
Default Re: sometimes car wont start after a 10-15 drive
currently on my z6 motor
Old Mar 8, 2013 | 03:47 PM
byronl's Avatar
Sounds like ur main relay could be it.
Old Mar 10, 2013 | 10:05 AM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help.
However, I agree with byronl, I would check the PGM-FI Main Relay first, it is a common problem on older Honda/Acura...
http://www.tegger.com/hondafaq/mainrelay.html
http://techauto.tripod.com/mainrelay.htm
You can also just listen for the fuel pump priming.
When engine does not start, turn ign. switch on to the run position, [not all the way to start] and listen for the fuel pump, it should run for a few sec., if not the problem is either the PGM-FI Main Relay or the fuel pump itself.
I would also pick up an HEI spark tester and check for spark when engine will not start. 94
Old Mar 11, 2013 | 09:58 PM
gregs_95_teg's Avatar
Check the main relay
Old Mar 12, 2013 | 01:06 AM
omgwtf's Avatar
Thanks alot guys! It was the main relay after all! :D
Old Mar 13, 2013 | 02:22 AM
JDMtube's Avatar
Relay first then the ECU will not initialize. Just wait for it. Have a stash of ECU's that only start the car when they feel like it. Waiting for someone to come by and rescue them.
mibayaua
Oct 28, 2012 11:40 PM
Lightsped
Jan 15, 2009 10:12 PM
sup22
Nov 3, 2007 01:22 PM
rls669
12
Jun 19, 2006 05:46 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
