Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Improper battery connection. Might have caused a blown fuse?
Old Mar 8, 2013 | 09:33 AM
Jerkface38's Avatar
Default Improper battery connection. Might have caused a blown fuse?
Ok so my battery died and I went to get another one. I started hooking it up and the cables didn't reach so I just turned it around. They reached. Unfortunately it was the wrong connections that reached and I seemed to have screwed something else up. Although at first it wouldn't fit my cousin decided to hammer the end on that didn't fit =/ anyways I was told that I probably blew some fuses and/or a relay and possibly the alternator. A few other people said I could have completely screwed up the electrical system but the majority said relay/fuses. I have a feeling it's the relay and possibly some fuses but I have no idea how to test a relay and I can't even get the dam thing to come out. I don't think I should just yank the relay out. The Civic is a 2003 Honda Civic EX. I have located all of the fuses/relays so any help on how to take them out and test them would be nice. Thanks for all the reply's in advance.
Old Mar 8, 2013 | 12:22 PM
toyomatt84's Avatar
Sanji
Default Re: Improper battery connection. Might have caused a blown fuse?
Check the 80A fuse in the fusebox under your hood. You might have fried it.
Old Mar 8, 2013 | 02:39 PM
Jerkface38's Avatar
How do I check it? It's like screwed on or something. I've never delt with anything on cars other than changing the fluids and changing the breaks. I've never even changed a battery other than this time
Old Mar 8, 2013 | 02:45 PM
toyomatt84's Avatar
Sanji
Its the big fuse in the front of the fuse box. You should be able to see inside the fuse itself to see if it is blown.
It looks like the one in the center of the photo here, just left of the finger:
Old Mar 8, 2013 | 02:52 PM
Jerkface38's Avatar
Ok I checked it and it looks split. I compared it to the 40 and the 40 isn't split so I'm assuming that it's the 80 causing the problems. Thank you so much I really hope this is it. Also I forgot to ask if you know how I should go about replacing it. I'm assuming I unscrew it but I don't want to mess anything else up. Thanks again.
Old Mar 8, 2013 | 03:45 PM
toyomatt84's Avatar
Sanji
Make sure to disconnect the battery, then proceed by unscrewing the fuse. Its rather simple to replace.
Old Mar 8, 2013 | 03:56 PM
Jerkface38's Avatar
Yes I did all this and disconnected the battery first and now the car works now I have to figure out why it overheated in the rain XD Thank you so much!
HotImportNightHonda
14
Oct 10, 2024 12:34 PM
ericbikes
Apr 9, 2019 04:00 AM
FastHatch90
Apr 3, 2006 07:47 PM
Mr. Vapor
Jun 15, 2004 09:24 AM
jaje
Jun 14, 2002 01:07 PM
