need help with a/c!!!
1998 honda civic lx automatic transmission
So when I first start my car the ac lines freeze up and so does the top of the compressor, I need to know what is causing this, the car doesn't run funny at all when this happens. The ac works fine up until I drive on the highway for 10+ minutes. Then its like no air will come through vents , it will shoot out frost
i googled this and found this quote from honda-tech
You have a bad expansion valve, its flooding the evaporator. The job of the expansion valve is to regulate the flow of freon into the evaporator. The high pressure switch signals the PCM to shut off the compressor when a XX amount of pressure is built in the high side. Since the expansion valve is stuck open the high side never has a chance to build enough pressure to reach the cut off threshold which keeps the compressor running continously.
I've noticed too when I'm driving you can hear coming from the glove box area almost sounds like "ice cracking" but i'll have to check that expansion valve out! Do you know if I'll have to release the ac refrigerant to replace it?
They might charge about $100 if it's just the expansion valve.
Yeah I know, the only problem is that the only shop in my town that was an ac shop, the owner past away from cancer
But as far as parts go I've currently got:
New compressor* the last one "blew up"
New condenser
New drier
Thanks for the response and knowledge!
New condenser
New drier
gqstatus05
Aug 20, 2009 11:31 AM
disboitrung
Aug 5, 2008 07:28 PM
pointman05
Sep 4, 2007 10:18 AM
