HELP!!! ENGINE SWAP HONDA CIVIC EX
Old Mar 6, 2013 | 06:40 PM
MRcerna's Avatar
Default HELP!!! ENGINE SWAP HONDA CIVIC EX
i have a 1995 honda civic EX coupe with a messed up engine there is a hole in the block i have a good older engine it is a 1990 acura integra 1.8L 4-cyl DOHC 16 valve engine i honestly dont know to much about cars but i need to know if this will work without needing to get the computer and the wire harness for the engine but if i do need the computer and wire harness what do i get?
Old Mar 6, 2013 | 07:11 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Default Re: HELP!!! ENGINE SWAP HONDA CIVIC EX
Google does wonders!!!
Old Mar 6, 2013 | 07:25 PM
MRcerna's Avatar
two straight days on google and cant find a straight answer
dewey_civic's Avatar
No, and bump to speedjunkie g35
Old Mar 6, 2013 | 08:14 PM
jbpnoman's Avatar
...Really? If you spent two days on Google, you weren't searching correctly. I'll give you a hint: 95 civic motor swap. Alternatively, you could read the FAQ's sticky, because there's a HUGE chunk of information that will tell you EXACTLY what you want.
Old Mar 6, 2013 | 09:12 PM
bladesz42's Avatar
so your wanting to know how to put a b series in a 95 honda civic? how do you not find that in 2 days of searching....
https://honda-tech.com/forums/hybrid-engine-swaps-18/definitive-guide-gsr-eg-swap-2976738/
took me all of 30 seconds
Old Mar 7, 2013 | 05:28 AM
Look it's simple. You got the engine get the computer for the same year. What ever jumper cables you need and a wire harness for that engine. And do research.
missmouse1971
Honda Civic (2001 - 2005)
Jan 30, 2018 07:21 PM
Bifferson
Jan 13, 2016 10:54 AM
knobby44
Nov 2, 2012 08:26 AM
prettypegagirl
Oct 31, 2011 05:43 AM
Bobby Rice
Aug 14, 2009 10:39 AM
