1999 CIVIC SI CLUSTER PROBLEM!!! NEED HELP
Old Mar 6, 2013 | 05:29 AM
1999jdm's Avatar
Default 1999 CIVIC SI CLUSTER PROBLEM!!! NEED HELP
I HAVE A 1999 CIVIC SI ,WHEN I TURN THE KEY THE MPH NEEDLE GOES TO 20MPH.AND STAYS THERE WHEN CARS RUNNING.AND THE RPM GUAGE DOES NOT WORK. ANY IDEA'S? PLEASE HELP IK REPLACED THE HEAT/TEMP PEICE IN THE CLUSTER.I HAD A EX CLUSTER IN BEFOR AND WORKED GOOD, MABYE BAD SI CLUSTER? PLEASE HELP.
Old Mar 8, 2013 | 06:10 AM
98b16sc's Avatar
Default Re: 1999 CIVIC SI CLUSTER PROBLEM!!! NEED HELP
my friends car did the same thing we had to replace the cluster
Old Mar 8, 2013 | 06:24 AM
apexi_rsx's Avatar
bad cluster you can try swapping the internals from an old cluster . taking the needle off is tricky but do able if ur carefull.
Old Mar 9, 2013 | 04:13 AM
1999jdm's Avatar
I did replace the gas/temp guage now it works great
I put diffrent rpm and mph guts in that i know work and now the rpm moves but when you turn the key bolth needles go up still .
Old Mar 9, 2013 | 04:23 AM
1999jdm's Avatar
The needles seem to float in my cluster. Anyway of mabye them needing repositioning ?
I heard about keeping the needles off while cluster is in the car run it snd such then reinstall.
Old Mar 9, 2013 | 05:25 AM
ThaiRacer's Avatar
Sell the cluster to me lol
Old Mar 9, 2013 | 09:30 AM
1999jdm's Avatar
$200 its urs
Old Mar 10, 2013 | 01:40 AM
nukkaplease333's Avatar
Mine did the same thing. Ended up doing what you mentioned and somehow it worked after that. Took needles off, drove to work (20 miles) and back. Put speedo back on with the car running, then tach with the car off. Worked great after that.
Old Mar 10, 2013 | 05:54 AM
stevenr2894's Avatar
Check your speedo. Mine had a bad ground. I jumped a ground wire. Fixed it
Could be a bad speedo as well. Pig tail could be loose? Check the lil things before popping ur cluster open. IMO that's last thing you wana do. Especially to a original SI cluster, which are expensive in hard to find
Old Mar 10, 2013 | 09:10 PM
1999jdm's Avatar
I checked the wiring its good. Still the needles float to a certain point and stop .. When the keys off (car not running and turn off ) they go back down. The mph guage works when u drive but it starts off at 20mph . Does anyone know a good place that can fix the rpm and the speedo guage? The needles were removed . Mabye it messed it up?
Old Mar 19, 2013 | 08:03 PM
That could do it. Set the needle's
Old Apr 17, 2013 | 04:22 AM
1999jdm's Avatar
wasnt a speed sensor just recalibrated my cluster works greattt now thanks for the help (:
SIDreamer
Feb 10, 2010 09:50 AM
DaFredsta
Oct 18, 2009 01:31 AM
luvmihatch
Jun 14, 2008 09:36 PM
aziaticvang
Jan 8, 2008 06:41 PM
thisboyjulio
Sep 5, 2007 05:42 PM
